Thread started 19 Apr 2013 (Friday) 00:31
Best 5D3 focusing setting with 85LII
MFG
Apr 19, 2013 00:31 |  #1
Hi,
I like to glue a new 5D3 to the 85LII. I am using it for wedding.
Has anyone here have any good focus setting on your 5D3 that you tested and like with high rate of accuracy of good keeper rate?
I know that the 5D3 has a few senarios for focusing, which do you prefer?
cheers,
Scott
AIPP Accredited (Australia), WPJA
Professional Wedding, Newborn and Family Photographer
https://www.scottgohph​otography.com.au (external link)
https://www.facebook.c​om/ScottGohPhotography (external link)
https://www.scottgohph​otography.com.au/blog (external link)
https://www.scottgohph​otography.com.au/babie​s-and-children/ (external link)
kin2son
Joined May 2011
Apr 19, 2013 01:00 |  #2
Single crosstype point using spot focusing?
5D3 Gripped / 17-40L / Σ35 / 40 Pancake / Zeiss 50 MP / Σ85 / 100L Macro / 70-200 f2.8L II IS / 430 EX II / 580 EX II / Canon 2xIII TC / Kenko Ext. Tubes
EOS M / EF-M 18-55 / EF-M 22f2 / Ricoh GR aka Ultimate street camera :p
Flickr (external link) | My Images on Getty®‎ (external link)
MFG
Apr 19, 2013 01:10 |  #3
spot focusing i believe. i focus on single spot if that is what you are asking. i think i had all the boxes ticked for the focusing type.
i dont have my camera with me right here to see.
najik
Joined Apr 2012
Apr 19, 2013 01:12 |  #4
I just recently got this lens for my 5Diii. I use single point AF or single point spot AF placed on the eye, usually the center point. Its definitely worth the time to test and set the micro-focus adjustment. I currently use a setting of +3 to correct some front focusing. That said, my miss-rate is still frustrating. If you have the patience for it, live view autofocus is rock solid. ;)
I think a big part of my problem is that I'm shooting wide open at close distances, so my depth of field feels like its approximately 2-3 microns, and if it doesn't land exactly where I want it to (the eye usually) it feels like a failed shot. I should probably back up or stop down. But I never seem to want to.
snake0ape
Apr 19, 2013 01:25 |  #5
I assume wide open. If you shoot on the spur of the moment, or the subject or yourself is walking, shoot Al_servo single xpoint focus. Any of the xtypes will work very well. Aim for the eyes by moving the joystick around. I never had a problem with the non-xtypes if the lighting is adequate.
5Diii | 50D | 8-15L 4| 16-35L 2.8 II| 24-70L 2.8 II | 70-200L 2.8 IS II |Tamy 150-600 | Σ35Art 1.4 | 40 2.8 | Σ50Art 1.4 | 85L 1.2 II | 100 2.8 Macro | Helios 44-3 58mm f2.0 |Helios 40-1 85mm f1.5 | 1.4x & 2x teleconverters
bratkinson
Joined Dec 2011
Apr 19, 2013 01:57 |  #6
For what it's worth, I usually shoot with my 135 f2L at f2.2 or f2.5...just for the little extra DOF. My keeper rate noticably improved vs wide open.
My only non-L is the 85 1.8. Maybe someday I'll spring for the L.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." General George S Patton, Jr 1885-1945
agedbriar
Apr 19, 2013 08:03 |  #7
Wasn't the question about AF configuration (Case 1 - Case 6) ?
MFG
Apr 19, 2013 08:05 |  #8
agedbriar,
yes and no,.... case 1-6 is part of the focusing thing. cross type affect the focus as well. as for now, i'm using case 2 since i photo people with lesser movement
sonnyc
Joined Jun 2005
Apr 19, 2013 10:58 |  #9
I found that if shooting in low light, spot focus is not as reliable as regular center point focus since the area of focus is too small and many times not enough contrast to lock.
I normally use back button focus with center point and 4 points assistant and prime it a few times to make sure.
Sonny
KO ­ Pop
Apr 19, 2013 17:38 |  #10
BBF helps
links
MFG
Apr 22, 2013 01:17 |  #11
may i know what is BBF?
Simpleboy
Apr 22, 2013 01:26 |  #12
Back button focusing,
Basically you disengage AF from the shutter button and only use the AF-ON button (some people prefer using *)
MFG
Apr 22, 2013 02:07 |  #13
Simpleboy wrote in post #15853680 (external link)
Thank you for the explanation.
2,088 views & 0 likes for this thread, 9 members have posted to it.
Latest registered member is EBiffany
959 guests, 111 members online
