FORUMS Photo Sharing & Visual Enjoyment People
Thread started 21 Apr 2013 (Sunday) 22:18
How does my lighting look?
Tiller
Joined Feb 2013
Apr 21, 2013 22:18 |  #1
First time ever using a flash through an umbrella. First time using a flash for that matter. I'm still trying to figure out all the best positions, angles, etc. CC welcome and desired. I know I have a lot to learn :D Thanks!
IMAGE: http://farm9.staticflickr.com/8540/8669931091_8b3c6d8c47_b.jpg
IMAGE LINK: http://www.flickr.com …/60111556@N03/8​669931091/  (external link)
IMG_5447 (external link) by tsmcdona (external link), on Flickr
Canon 60D|Tamron 90mm 52B|Canon 50 1.8|Canon 85 1.8|Yongnuo YN-568ex|Manfrotto 055XProb with 498RC2|Fuji AX Multi Program with 50 1.9 and 135 2.8|Mamiya 645 Pro with 85 2.5|
Website: http://tylersmcdonald.​com (external link)
kouasupra
Apr 22, 2013 05:13 |  #2
Doesn't look too bad. Decent I think. Where was the flash position?
Tiller
Joined Feb 2013
Apr 22, 2013 08:04 |  #3
About 45 degrees to my left. You can see in the catchlights.
fashionrider
Joined Dec 2011
Apr 22, 2013 08:48 |  #4
I RARELY ever use a single light from below. It casts shadows upwards and just doesn't look as good. Sun is always above us so it looks more natural with a light source up high.
Gear List (5D3, 70-200 f2.8L IS II, Sigma 85mm f1.4, Sigma 35mm f1.4, 50 f1.8, 24-105L, Alien Bee lights, etc etc)
bbvdm
Apr 22, 2013 08:58 |  #5
It looks a little too harsh. A little too "flashy". I think you need to lower the power on your flash. Also, raise the light to point down a little more. The shadow from her nose should be going down slightly and should be not so prominent. The catch light should be higher in the eye. What you are working on is "Loop" lighting.
Canon 5D MkII gripped, Canon 7D gripped, Canon 40D gripped, Canon XTI (IR) gripped, Canon 17-55 2.8 IS, Canon 60 Macro 2.8, Canon 70-200L 2.8 IS , Canon 24-105 4.0, Tokina 11-16 2.8, Canon 50mm 1.8, Sekonic L-358, Canon Speedlite 580-EX II, (2)430-EX, Pocket Wizards, lots of other stuff that seems to keep growing...:lol:
Tiller
Joined Feb 2013
Apr 22, 2013 10:49 |  #6
Ok thanks guys. The reason I had it low is bc there was a ceiling light that was lighting up the top of her head, so I thought I should put it down low to get rid of the shadow underneath her chin.
I'll get it up higher next time!
swampler
Apr 22, 2013 18:59 |  #7
Your flash is going to be your main light, it will over power the room light. You could use a reflector or 2nd flash to fill in shadows.
Steve
RSBurton
Apr 23, 2013 22:03 |  #8
Looks a little hot,
7D / 28-135, Canon 50mm f/1.8, 85mm, Canon 24-70mm 2.8 I, 50-250mm IS, (3) 600ex-rt
mkhirale
1 post
Joined Apr 2013
Apr 24, 2013 02:30 |  #9
But,not bad.U look like very well.I like ur photo...............:D
<a href="http://www.prans​oft.in"><b>SEO Service India</b></a>
tlzimmerman
Joined Jan 2012
Apr 24, 2013 14:37 as a reply to  @ mkhirale's post |  #10
Raise it a little, its a little bit overexposed, like 1/4 stop for my taste, and a bit warm too for my taste, probably due to the yellow walls.
5d Mk III - 5d Mk II - 550d - 24-70L - 70-200L IS II - 24-105 F4 L - 85 1.8 - 50 1.4 - 60 Macro - 15 Fisheye
catalystsupreme
Apr 24, 2013 14:56 |  #11
Try using a different modifier (softbox perhaps) or back it up a bit. A little harsh IMO
www.garyfikes.com (external link)
Canon 5D MKIII Gripped Canon 7D Gripped Canon : Canon 135mmL Canon 24-70mmL Canon EF 50mm f/1.4 : Canon EF 28-135mm f/3.5 : Tokina 11-16mmf/2.8 : 4 Speedlite 600ex : Canon Speedlite 430 EXII : 4 YN-560's
nathancarter
Gallery: 32 photos
Apr 24, 2013 21:01 |  #12
Tiller wrote in post #15854737 (external link)
In a case like this, you WANT a shadow under the chin; it'll give her a more defined jawline.. which just about all ladies want.
Right now she has no defined jawline on her left (camera right) side of the face; the cheek flows down over the side of the chin and into the neck. Not very flattering.
swampler
Apr 24, 2013 21:25 |  #13
nathancarter wrote in post #15864227 (external link)
I think that's head position more than lighting. The feminine head tilt bunches the skin up on her left side. Tilting the other way and stretching the neck a bit would probably help with that.
Steve
nathancarter
Gallery: 32 photos
Apr 24, 2013 21:36 |  #14
Agreed - but you can still get a bit of shadow down there if the light is raised, which would probably give a bit more jaw definition.
swampler
Apr 24, 2013 21:43 |  #15
I should read closer before posting. I see what you were saying now and agree that a shadow would help as well.
Steve
2,380 views & 0 likes for this thread
Latest registered member is countrygirl67
811 guests, 189 members online
