when I shoot with 5D2 and 70-200 mm lens red roses, they seem to be over saturated, what filters or adjustments can I do,any other tips in shooting red? I try to under saturate and hue adjust in LR4.
tonyniev Cream of the Crop More info | Apr 22, 2013 13:24 | #1 when I shoot with 5D2 and 70-200 mm lens red roses, they seem to be over saturated, what filters or adjustments can I do,any other tips in shooting red? I try to under saturate and hue adjust in LR4. Cheers,
kirkt Cream of the Crop More info | Apr 22, 2013 13:43 | #2 How are you exposing your shot? In this situation, red will really dominate the image, so expose for the red channel. Some folks will bracket, some will go for it and use a UniWB approach to see the red channel with WB multipliers all set to 1, so they can use the red channel as an exposure guide. Kirk
Scatterbrained Cream of the Crop 8,511 posts Gallery: 267 photos Best ofs: 12 Likes: 4607 Joined Jan 2010 Location: Yomitan, Okinawa, Japan More info | Apr 22, 2013 13:44 | #3 Try using a brush to only desaturate the areas that are clipping. VanillaImaging.com
Apr 22, 2013 13:52 | #4 Okay thanks will try these. Cheers,
Apr 22, 2013 14:03 | #5 This has been a trait of Canon sensors that started in ernest with the 40D and still continues. A workaround is to set the camera's histogram for RGB and expose to avoid clipping the red channel. Then in post processing, pull down the saturation on the red channel a bit. By using the historgam correctly for exposure you can still retain detail in the reds that might have otherwise been list. Gear List
Apr 22, 2013 14:13 | #6 seeking additional advise and comments Camera calibration red saturation adjustment (DUPLICATE IMAGE) HSL adjustments camera calibration (DUPLICATE IMAGE) Cheers,
| Latest registered member is semonsters 1634 guests, 136 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
