Why can't I save a *.gif directly to *.jpg? I have to save it as another file format first.
Am I missing something, or are the two formats just that far apart?
I have CS5, btw.
Apr 22, 2013 20:03 | #1 Why can't I save a *.gif directly to *.jpg? I have to save it as another file format first. Website: Iowa Landscape Photography
BigAl007 Cream of the Crop 8,118 posts Gallery: 556 photos Best ofs: 1 Likes: 1681 Joined Dec 2010 Location: Repps cum Bastwick, Gt Yarmouth, Norfolk, UK. More info | Apr 23, 2013 04:07 | #2 If you have a GIF format image open in PS you should be able to do a save as JPEG. you might want to check that the image is open as an 8 bit RGB image. If it is in another format then you would need to change it. This should be under the Image tab of the menu bar.
Kolor-Pikker Goldmember 2,790 posts Likes: 59 Joined Aug 2009 Location: Moscow More info | Apr 23, 2013 04:14 | #3 Because a GIF may be saved as indexed color, in which case you should go to Image -> Mode -> select RGB color. Then you can save it as Jpeg. 5DmkII | 24-70 f/2.8L II | Pentax 645Z | 55/2.8 SDM | 120/4 Macro | 150/2.8 IF
| Latest registered member is Niagara Wedding Photographer 1537 guests, 168 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
