Thread started 24 Apr 2013 (Wednesday) 13:18
L-Plate for RRS heads
shedberg
Apr 24, 2013 13:18 |  #1
I'm thinking about ordering a Really Right Stuff ballhead and an L-Plate for my 6D. I'm just curious, how does the L-Plate slide out for portrait orientation? I see it slides out a bit to make room for shutter release cables and whatnot, but how do you do it? Do you have to loosen the bolt on the bottom every time? How solid is it, does anyone have issues with it slowly slipping downwards when sitting on the tripod?
6D / 7D / 16-35 II / 35 2.0 IS / 60 macro / 85 1.8 / 135 2 / 100-400 / 430EX II
tgara
Apr 24, 2013 13:33 |  #2
shedberg wrote in post #15862711 (external link)
You simply release the clamp, rotate the camera 90 degrees to the upward part of the L, then re-clamp.
Watch this video at about the 1:40 mark.
http://reallyrightstuf​f.com/WebsiteInfo.aspx​?fc=42 (external link)
EOS 5D Mark III
EOS Rebel SL1
Full Gear List
shedberg
Apr 24, 2013 13:50 |  #3
If you look at this product page for the L-Plate for the 6D, it slides out for portrait orientation.
http://reallyrightstuf​f.com …for-Canon-6D-without-grip (external link)
v35skyline
Apr 24, 2013 14:38 |  #4
This is the type of question that should really be addressed with RRS directly. They have live online chat support, email, and phone.
I would assume that it does need to be loosened.
X100s | X-Pro1 | X-T1 | XF 14 | XF 18 | XF 35 | XF 56 | XF 60 | XF 10-24
Gear List & Feedback
shedberg
Apr 24, 2013 15:24 |  #5
Probably... was hoping someone on here had one and knew how it worked.
v35skyline
Apr 24, 2013 16:05 |  #6
You'd get a much quicker and more accurate response from RRS.
Unbalanced
As one of the gluttons for punishment, I'm glad to see Chet's back
Gallery: 72 photos
Apr 24, 2013 16:32 |  #7
The example you refer to appears to be using a USB cable.
All of my releases use a 90* plug, which the RRS bracket clears just fine. I've not had to reposition the bracket.
It looks to me like you'd have to loosen the clamp bolt to reposition anytime you'd want to shoot tethered with a USB cable in portrait.
The crux of the biscuit is the apostrophe.
shedberg
Apr 24, 2013 16:36 |  #8
Unbalanced wrote in post #15863433 (external link)
Ahhhh, I see now. Thanks very much, Unbalanced!
Unbalanced
Gallery: 72 photos
Apr 24, 2013 17:50 |  #9
No worries.
Go with the RRS gear.
You won't be disappointed.
tgara
Apr 24, 2013 18:11 |  #10
shedberg wrote in post #15862842 (external link)
Yeah, I see what you are talking about now. I believe they allow the plate to slide so you do not need a spacer to connect a cable release. Judging from the bottom shot photograph, it appears that you must loosen the connecting bolts in order to allow the plate to slide. However, if you are concerned, I would call our RRS directly and ask them about it.
EOS 5D Mark III
EOS Rebel SL1
Full Gear List
3,016 views & 0 likes for this thread, 4 members have posted to it.
954 guests, 109 members online
