Thread started 26 Apr 2013 (Friday) 20:53
7D vs cropped 5d III = same image???
guntoter
Apr 26, 2013 20:53 |  #1
I heard something in another post that made me wonder if it is true. The poster said that you don't really need a 7D for reach because you can just use a 5D III and crop the image to get the same result as the 7D without crop.
Is that true? Anyone with experience with this? I have a 7D, and want a 5D III to go along with it, however, I would really like to know it this statement is true.
Joel
GEAR
maverick75
Joined May 2012
Apr 26, 2013 20:58 |  #2
I was the one who said it, I figured it out by accident when I started in photography, check out this thread:
https://photography-on-the.net …/showthread.php​?t=1217121
Haven't you ever wondered why they're called crop cameras? ;)
Choderboy
I like a long knob
Gallery: 185 photos
Apr 26, 2013 20:59 |  #3
No
Maths was done in a current thread
"which full frame lense..
5D111 cropped to 1.6 is about 9MP
I apply old known example.
5 D classic FF 12.8MP
cropped to 1.3 (more accurate 1.25) 1DMKII = 8.2 MP
cropped to 1.6 = 5MP (1.6 at the time was 8.2MP)
Crop FF to 1.6 and result is fair bit less than half MP.
Dave
Image editing OK
Choderboy
I like a long knob
Gallery: 185 photos
Apr 26, 2013 21:00 |  #4
maverick75 wrote in post #15871295 (external link)
Ears burning ? :)
EDIT:
Actually, your ears are probably normal temp.
It was Tom in this thread commenting on the 9MP result of cropping 5D3
https://photography-on-the.net …/showthread.php​?t=1294464
Dave
Image editing OK
gjl711
Apr 26, 2013 21:46 |  #5
The math:
7D = 5184 by 3456 and a sensor 22.3 by 14.9 which yields about 232 pixels per linear mm of sensor.
5DIII = 5760 by 3840 and a sensor 36 by 24 which yeilds 160 pixels per linear mm of sensor.
So, multiplying the 7D sensor size by the 5DIII pixel density you get a image of 3568 by 2378 or 8.49 megapickles.
With that said, the only time it's going to make a difference is if you are cropping a 7D image such as bird photographers do all the time. Then the 7D put a whole lot more pixels on the target or if you are printing large images. Pictures shrunk to web size have nearly all the data tossed away anyways.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
LowriderS10
Apr 26, 2013 22:19 |  #6
All you would have had to do is look up "pixel pitch" for each camera...if the pixel pitch is not the same (which it isn't), then the resulting "cropped" image won't be the same either.
-=Facebook=- (external link)
-=Flickr=- (external link)
-=Gear=-
dalto
Apr 26, 2013 22:23 |  #7
It depends what you mean.
The image from the 7d will have much more pixel density.
However, the image will be the same as the crop. It depends what you limiting factor is and what you are doing with the image. If you are going to crop it even further the 7d may have an advantage depending on the resolution of the lens.
guntoter
Apr 26, 2013 22:43 |  #8
Thanks for the input on this subject guys.
From what I am hearing the 7D will be better for birding etc.
Still want a 5D III for other photography.
5D III as primary, and 7D for backup. What a fantastic pair.
Joel
GEAR
LowriderS10
Apr 26, 2013 22:57 |  #9
Yup.
-=Gear=-
Citex
Apr 27, 2013 00:10 |  #10
They are a great setup together.
http://ryanburleson.co​m (external link)
5d3/7d/70-200 2.8 IS II, 16-35 2.8 II L's/Sigma 35 1.4 A/st-e3-rt/2x600ex-rt
Fuji x100s, x-t1, 56mm 1.2, 18-55 2.8-4 OIS
Edwin ­ Herdman
Joined Aug 2011
Apr 27, 2013 01:42 |  #11
gjl711 wrote in post #15871419 (external link)
You don't even need to crop a 7D image to get the benefit - if the bird is filling the sensor plane, that's a lot of cropping in a full-frame image (which will be, as noted earlier here, about half as detailed, in terms of total pixels, though the full-frame image should have considerably better than half the horizontal and vertical detail).
This happens to me pretty frequently, actually.
DreDaze
Gallery: 49 photos
Apr 27, 2013 01:59 |  #12
the fact that the 5DIII will soon be able to auto-focus at f8, kinda negates any benefit a 7D may have...you could just throw a 1.4X TC on most lenses to get more pixels on target with the 5D
Andre or Dre
gear list
Instagram (external link)
Edwin ­ Herdman
Joined Aug 2011
Apr 27, 2013 02:26 as a reply to  @ DreDaze's post |  #13
'cept I've already got a 2X TC on my lens :cool:
Madweasel
Apr 27, 2013 04:45 |  #14
DreDaze wrote in post #15871842 (external link)
Although you could indeed AF at f/8 with a 1.4x extender on the 5DIII, that would limit you to centre-point focusing only, whereas the 7D at f/5.6 would still have 19 cross-type AF points for use, so not quite the same in practice.
Mark.
DreDaze
Gallery: 49 photos
Apr 27, 2013 04:58 |  #15
Madweasel wrote in post #15872025 (external link)
why would it be center point only? i thought it would work with all the cross type AF points...
Andre or Dre
gear list
5,558 views & 0 likes for this thread, 21 members have posted to it and it is followed by 2 members.
1054 guests, 103 members online
