Thread started 27 Apr 2013 (Saturday) 06:46
Correct 17-40 pyramid effect in LR or PS?
Roxie2401
Apr 27, 2013 06:46 |  #1
Is there a way to correct the slight inverted pyramid effect caused by a 17-40 when taking interior room shots in Lightroom or do I have to go to PhotoShop to do this? I have found the lens profile correction but are there other tools in LR to use?
What I am seeing is a slight outward shift from floor to ceiling on side walls and need to straighten these walls.
gjl711
"spouting off stupid things"
Apr 27, 2013 06:48 |  #2
I dont believe that LR will do this correction. You can avoid it in the first place by making sure that the camera is parallel to the ground when you take the picture and not pointed up or down.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
Roxie2401
Apr 27, 2013 06:50 as a reply to  @ gjl711's post |  #3
Do you know that tool(s) to use in PhotoShop, if not in LR? Thanks
sapearl
Gallery: 148 photos
Apr 27, 2013 06:55 |  #4
In Photoshop it is: FILTER -> LENS CORRECTION -> CUSTOM -> and then Transform VERTICAL PERSPECTIVE. I also use the 17-40 and you just have to be careful as JJ suggests and initially make sure the camera is parallel to the ground.
MY WEBSITE (external link)- MY GALLERIES (external link)- MY BLOG (external link)
Artists Archives of the Western Reserve (external link) - Board
gjl711
Apr 27, 2013 06:57 |  #5
Roxie2401 wrote in post #15872170 (external link)
In PS it's under the Filter then Lens Correction. When the image pops up, click on the "custom" tab on the right. Then under the custom adjustments, the one your looking for is the "vertical perspective". Turn on the grid, adjust until the lines are looking right then crop to fit.
::Gear::
Roxie2401
Apr 27, 2013 07:03 as a reply to  @ gjl711's post |  #6
Interesting - in LR there is also a vertical and horizontal perspective correction in the Lens Correction Perspective that presents grid lines.
Is cropping required after correction in PS?
sapearl
Gallery: 148 photos
Apr 27, 2013 07:05 |  #7
Roxie2401 wrote in post #15872191 (external link)
I can't speak for LR, but not for PS at this menu unless you wish.
Roxie2401
Apr 27, 2013 07:55 as a reply to  @ sapearl's post |  #8
This is a big help - I thought I would have to use the "Skew" tools.
Rimmer
Joined Nov 2010
Apr 27, 2013 08:23 |  #9
Lightroom: Develop > Lens Correction > Manual > Transform > Vertical. Check the Constrain Crop box.
Ace Rimmer -- "What a guy!"
"Smoke me a kipper, I'll be back for breakfast." ;)
tzalman
Fatal attraction.
Apr 27, 2013 08:54 |  #10
LR4 does it if you don't want to break the non-destructive workflow, but it's easier in other applications. LR5 will do an automatic correction that may need a little manual tweaking.
Elie / אלי
1,035 views & 0 likes for this thread
Latest registered member is Guashumerda
795 guests, 197 members online
