Thread started 28 Apr 2013 (Sunday) 02:32
Need a prime: Help me to analyse my focal length
drmaxx
Gallery: 41 photos
Apr 28, 2013 02:32 |  #1
Currently, I have 2 lenses: 15-85mm and a 50mm/1.4
I would like to buy an other fast prime that I can use without flash. The 50mm is often too narrow in confined spaces.
I analyzed the 'keepers' of a longer period of using both lenses. Based on that, which lens would you buy? (Currently, I am thinking of the Canon 28mm/2.8 IS and the new Sigma 35mm)
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/04/4/LQ_646891.jpg
Image hosted by forum (646891) © drmaxx [SHARE LINK]
Donate if you love POTN
kin2son
Joined May 2011
Apr 28, 2013 03:12 |  #2
I wouldn't call a f2.8 prime fast nor suitable for indoor, and IS is only useful for shooting static stuff.
Sigma 35 is an overkill on crop, unless you are going ff soon.
My recommendation is the new Sigma 30 Art. Fast, resonable price and sharp.
5D3 Gripped / 17-40L / Σ35 / 40 Pancake / Zeiss 50 MP / Σ85 / 100L Macro / 70-200 f2.8L II IS / 430 EX II / 580 EX II / Canon 2xIII TC / Kenko Ext. Tubes
EOS M / EF-M 18-55 / EF-M 22f2 / Ricoh GR aka Ultimate street camera :p
Flickr (external link) | My Images on Getty®‎ (external link)
LostArk
Joined Apr 2012
Apr 28, 2013 03:16 |  #3
Sigma 30 Art, no question
www.unknoahble.com (external link)
Sirrith
Gallery: 50 photos
Joined Nov 2010
Apr 28, 2013 03:18 |  #4
You do seem to favour 35mm, and 85mm. Since 85 is not one of your choices, I wholeheartedly recommend the Sigma 35. It is an absolutely stunning lens, and is just as fine on crop as on FF. You could alternatively save a bit of money and go with the new Sigma 30/1.4, although that is not quite as good as the 35 IQ-wise.
-Tom
Asroma
Joined Oct 2012
Apr 28, 2013 06:07 |  #5
35 L
Gear list| Canon 5d mk ii, Canon 40D 17-40 F4 L, 35 1.4 L, 85 1.8, 100 macro 2.8, 135 F2 L, 70-200 F4, 580 EX II
My Flickr at http://www.flickr.com/​photos/56983240@N03/ (external link)
pulsar123
Gallery: 82 photos
Apr 28, 2013 06:07 |  #6
Sigma 30mm Art.
But if you don't have a flash, getting one should be your priority. Using f1.4 primes indoors without flash results in bad lighting and too narrow depth of field in most cases. Flash light bounced off ceiling and walls will give you a much more significant IQ boost than a f1.4 prime.
6D (normal), 6D (full spectrum), Tamron 24-70 f2.8 VC, 135L, 70-200 f4L, 50mm f1.8 STM, Samyang 8mm fisheye, home studio, Fast Stacker
JeffreyG
Gallery: 42 photos
Apr 28, 2013 07:22 |  #7
Your selected focal lenths are fairly evenly distributed. I think you will need to sort the photos you take and look more at what type of shots you use each one for, and if those will be the types of shots you want to get the prime for or not.
One other note, you select primes to shoot from that focal length to longer. For example, a 35mm prime covers your needs from 35mm to ~60mm or so via cropping. So if you were to get a 35mm prime it would line up with that spike in your set at 35mm, but it wouldn't cover all of the shots you took from 15mm to 34mm.
I see this sometimes with people who have a 24-70 zoom on FF. They think about replacing the 24-70 with a single 35mm prime. But unless they never use the wide end of the zoom this approach misses something. A better replacement for a 24-70 is a 24mm prime and a 50mm prime.
In short - primes can serve to replace zoom ranges longer than the prime, but not zoom ranges shorter than the prime. You can't crop wider.
gasrocks
Apr 28, 2013 08:15 |  #8
Human nature. Give someone a zoom that goes from A(mm) to B(mm) and they will mostly use it at A and B. As mentioned already, look over your pix. Chart does not tell us anything really. Gene
drmaxx
Gallery: 41 photos
Apr 28, 2013 09:04 |  #9
gasrocks wrote in post #15875084 (external link)
:) That's exactly what I thought when I saw the graph.
I looked today extensively over these pictures and try to sort out the most probable use. There is quite some outdoor and technical stuff I shoot and most of this is well covered with the 15-85.
I guess the most use is for taking candid / spontaneous pictures in social settings. That's what I am using the 50 mm the most. I do have a flash, but would like to have a shallow depth of field and/or ignore the flash. The 50 on my crop 60D is great to isolate a single person. But as soon as I want more then just one face then I often simply don't have enough space to move back. The 50 is just too narrow to give me the flexibility I would like in such a setting.
So: 35 or 28 or even 24?
And on an other note: Is there any reason to go for the 35L instead of the new sigma 35 -- I am aware of the alleged QC issues. Looking at the reviews, I can not recognise any technical reason why I should spend the additional money on an L.
Sirrith
Gallery: 50 photos
Joined Nov 2010
Apr 28, 2013 09:07 |  #10
drmaxx wrote in post #15875196 (external link)
Nope.
-Tom
vengence
Joined Mar 2013
Apr 28, 2013 09:19 |  #11
Why exactly did you rule out an 85 when so many of your pictures are at that length?
gasrocks
Apr 28, 2013 09:59 |  #12
15-85 is a very limited range, IMO. You need to try out some 105, 135, 150, 200, etc.
JeffreyG
Gallery: 42 photos
Apr 28, 2013 10:02 |  #13
vengence wrote in post #15875226 (external link)
To me the huge number of shots the OP took at 85mm suggest that his next lens consideration should include something like a 70-200 or 70-300 zoom.
I don't see a 'love' of 85mm focal lenght there, I see somebody who really wants a lens that reaches longer than the current 85mm limit he has.
gasrocks
Apr 28, 2013 10:04 |  #14
The OP does not really know what an 85mm lens is though. His present one is f/5.6 = yuk.
artyH
Apr 28, 2013 10:16 |  #15
I have the older Canon 35 F2 and it is used more than my other lenses. It is a very useful focal length on a crop. If I were getting a lens for indoor, lowlight shots of people, I would look at the new Canon 35F2IS. The Sigma 35 is pretty big and heavy for a fast prime. If you have micro adjust on your camera, then the Sigma becomes an option.
4,229 views & 0 likes for this thread, 21 members have posted to it and it is followed by 2 members.
1130 guests, 166 members online
