Thanks for the input, I think I am slowly getting the idea
You might want to find an "auto-bellows" style,so you can set up with the lens at maximum aperture and quickly stop down to shooting aperture.
I understand the set up and stop down of aperture and why but do not understand the "auto-bellows" feature though have see it advertised.
Are you planning to do a lot of slides? if so, a slide duplicating attachment may be better than using a flat-bed scanner. A dedicated film scanner would be still better if you have a real lot of slides/negs to convert.
I only plan on doing a few hundred and this will be over time.
Figure the bellows will probably start you at around 1/2 life-size or more, depending on the lens you use. A "short-barrel" lens will let you take this to a lower magnification, since the short barrel versions make allowances for the size of the bellows proper.
When you say "short-barrel" lens do you mean short focal length? I'm still a little grey here.
The best lenses depend on what you want to photograph.
Aside from a few slides I would like to do close-up work with flowers, bugs that will cooperate and the like. It does seem like a 105mm lens is advertised for copying. I would imagine that the shorter the lens, the greater the magnification for the length of bellows extended.
Most normal lenses are excellent in macro applications when reversed, because they are optimized for the short distance to the film plane.
Is this to get greater magnification than mounted normaly? I assume the lens always goes on the end of the bellows, not the camera end.
I can mount my bellows and camera above using the Nikkor on a tripod pointing down to my light box, and put the slide on the light box, when I need to dupe slides. That gives me quite a lot of control over framing and so on.
I have seen this setup shown somewhere before, would be willing to try to replicate this for copying slides.
And I also have the 50mm macro, which is more convenient when I don't need true macro and also when I need a shorter working distance (such as reproducing prints on a copy stand).
I assume you mean using it such with out the bellows
Boy Rick, you sure do have a lot of middle names.
