Thread started 28 Apr 2013 (Sunday) 14:40
Can any Yongnuo Flash guns be triggerred optically by a single flash
Submariner
Joined May 2012
Apr 28, 2013 14:40 |  #1
Can either the Yongnuo YN-560EX or the Yongnuo YN-568EX be triggered by a single flash.
I heard a rumour the YN- 560EX could be???
per the specs:-
" 4, Multiple Trigger More Supported
The YN568EX can be triggered by the camera set-top, built-in or main-controlled flashing command, S1 and S2 (pre-flash-canceled mode)."
Is it the S1 or S2 pre-flash-canceled mode - that allows this?
If so that would be a cheap way to get some additional light to augment my Bowens studio flashes, which are triggered by Bowens Pulsar triggers. i.e. when the Bowens flashes it will trigger the Yongnuo. Plus I could use it outside in ETTL II mode with the 7D optically or worth getting a set of 622C's for location work!
NB I do not want to use the 622c in the studio as we have the Pulsar radio system linked to 3 remote controlled Bowens GM500R's.
Appreciate the adjustment would be all manual.
Canon EOS 5DS R, Canon EF 70-200 F2.8 L Mk II IS USM, Canon EF 70-300 F4-5.6 L IS USM, EF 40mm F2.8 STM , RC6 Remote. Canon STE-3 Radio Flash Controller, Canon 600 EX RT x4 , YN 560 MkII x2 ; Bowens GM500PRO x4 , Bowens Remote Control. Bowens Pulsar TX, RX Radio Transmitter and Reciever Cards. Bowens Constant 530 Streamlights 600w x 4 Sold EOS 5D Mk III, 7D, EF 50mm F1.8, 430 EX Mk II, Bowens GM500Rs x4
dedsen
Apr 28, 2013 16:13 |  #2
The S1 and S2 modes of YN flashes is the simple optical trigger function. So if they have these mode then you should be good. I am pretty sure that both of these flashes do have this mode.
Submariner
Joined May 2012
Apr 28, 2013 19:15 |  #3
dedsen wrote in post #15876372 (external link)
Thanks Dedsen,
So do you think I could use this with my studio strobes to augment them.
The pulsar Tx transmitter, mounted on the camera wirelessly triggers over radio the 3 Bowens stobes fitted with Pulsar reciever cards. Thus these can be in 3 seperate groups. Hopefully when any of these flash (on their own or together) this will fire the Yongnuos (obviously all the settings on the Yongnuos will have to be manual)
scorpio_e
Apr 29, 2013 16:53 |  #4
My YN 560's have the S1 and S2 modes.
www.steelcityphotograp​hy.com (external link)
1,188 views & 0 likes for this thread, 3 members have posted to it.
2532 guests, 90 members online
