LucasCK wrote in post #15881896
Ive had my 603c's for over a year now. Now I finally want to use them and found that HSS isn't compatible with them? I didn't think it mattered with triggers as just tell the flash when to fire and the flash sets the HSS?
Just my guess, but I'd be really surprised if HSS didn't involve the camera sending the shutter-speed duration to the flash, so it would know how long it needs to sustain the pulsing. A simple "fire!" signal won't cut it, since the flash has to know to a) shoot multiple bursts for b) a specific duration.
Am I doing something wrong?
Nope. It's the way the triggers work. They are manual-only. Even though all five pin/contacts are on the triggers (the one in the center of the square is the sync signal), the only use the other TTL pins are put to are for 1) identifying if the unit is on a camera hotshoe or on a flash to set Tx/Rx mode, and 2) wake-up. All the other TTL communication goes unrecognized.
You want HSS? You have to have an HSS-capable flash and TTL-capable triggers. The YN-622c, as everybody's telling you, is probably the way you want to go.
