Thread started 30 Apr 2013 (Tuesday) 19:02
Canon Battery Charger and lens step down question
viperbass
Joined Feb 2012
Apr 30, 2013 19:02 |  #1
We are going to Germany and Austria soon. I will have my Canon 60D and a Canon G9 with us.
I have the european 2 prong connector. Can I use both chargers (60D + G9) with only the 2 prong european adapter (no voltage converter)?
Second question on lens step down rings. I have 58MM and 67MM Canon lens. Can I use step down rings to use my 67MM filters (CPL & GND) on my 58MM lens?
Thanks to all who respond.
Jon
Joined Jun 2004
Apr 30, 2013 19:11 |  #2
Yes (but not at the same time, unless you have a cube tap), and Yes. If you go the cube tap route, make sure you use one that's heavy-duty. 240V wants a bit heftier wiring than 120 does.
Jon
Cocker Spaniels
Canon ­ Bob
May 01, 2013 02:28 |  #3
Jon wrote in post #15884582 (external link)
........ 240V wants a bit heftier wiring than 120 does.
It's the reverse, Jon, double the voltage requires half the current so the wiring can be thinner.
Back to the OP....the chargers will work just fine with a converter plug and the voltage (230v nominal) is no problem.
Bob
1Dx2 (2), 5DSR, 1Ds3, 1D4, 5D2(590nm), 5D2(720nm) EF600 EF400 EF300-II EF300 EF200 EF200-II EF180L EF135L EF100 EF85-II EF50L TS-E17/4 TS-E24L-II TS-E45 TS-E90 MP-E65 EF70-200-II EF24-70/2.8-II EF16-35/4 EF8-15/4 EF11-24/4 Zeiss 15/2.8 21/2.8 25/2 28/2 35/1.4 35/2 50/2 85/1.4 100/2 135/2 T/C's L-SC & a WIFE!
goldboughtrue
May 01, 2013 02:55 |  #4
You want step-up rings (from the lens size up to the filter size).
http://www.pbase.com/g​oldbough (external link)
5D II, Canon 100 macro, Canon 70-200 f/4L, Canon 24-105 L, Canon TS-E 45, Sigma Art 35mm f/1.4
348 views & 0 likes for this thread
Latest registered member is dayuan99
866 guests, 325 members online
