The adjustment brush works and does what it should do, but it no longer leaves the little circle behind over the image. This makes it impossible to go an edit a brush at a later stage. The graduated filter still works as usual and leaves a circle behind (one for each filter applied) for editing at a later stage, as usual.
Has anyone seen this before? I noticed this after upgrading to 4.4. Not in 4.3. Alas, when I restore back version 4.3 (from TimeMachine backup) this problem is NOT corrected. Neither if I restore an older .plist preference file.
Many thanks in advance for your help!
