Thread started 02 May 2013 (Thursday) 02:01
Hitech 100mm slide-in filter system explained for novices
jeffreybehr
Joined Apr 2013
May 02, 2013 02:01 |  #1
...and the first novice is ME! I've used a Cokin-P (85mm) slide-in filter system on lenses not as short as I now have, but that holder intrudes into the images of lenses of 24mm and shorter on FF bodies. After talking with the nice people at 2filter.com in New Hampshire, I bought the Hitech 100mm starter kit.
http://www.2filter.com …h4x5Gradualhold​erKIT.html (external link)
Here's what arrived, VERY quickly, I might add. We have the 77mm adapter ring, modular holder, extra screws and nuts, and 3 graduated neutral-density, 100X125mm (4"X5") filters. The kit comes with 1-, 2-, and 3-stop filters.
IMAGE: http://i89.photobucket.com/albums/k220/jeffreybehr/Hitech%20100mm%20Slide-In%20Filter%20System/2013May01_kit_1200w_zps6670e6c1.jpg
IMAGE LINK: http://s89.photobucket​.com …200w_zps6670e6c​1.jpg.html  (external link)
Here's some detail of the front of the holder with the 3 original holderclips installed.
IMAGE: http://i89.photobucket.com/albums/k220/jeffreybehr/Hitech%20100mm%20Slide-In%20Filter%20System/2013May01_holderedgetrio_1200w_zps15e4099f.jpg
IMAGE LINK: http://s89.photobucket​.com …200w_zps15e4099​f.jpg.html  (external link)
The 3 holderclips will hold 2 filters; if you slide a filter in the rear-most slot, it would not be held tightly and would fall out.
Here's detail of the rear of the holder. The thumbscrew tightens the holder onto the adapter ring.
IMAGE: http://i89.photobucket.com/albums/k220/jeffreybehr/Hitech%20100mm%20Slide-In%20Filter%20System/2013May01_holderbackside_1200w_zps0a564f3b.jpg
IMAGE LINK: http://s89.photobucket​.com …200w_zps0a564f3​b.jpg.html  (external link)
Some detail of the adapter ring, loose...
IMAGE: http://i89.photobucket.com/albums/k220/jeffreybehr/Hitech%20100mm%20Slide-In%20Filter%20System/2013May01_holderbacksidewring_1200w_zpsf6b46912.jpg
IMAGE LINK: http://s89.photobucket​.com …200w_zpsf6b4691​2.jpg.html  (external link)
...and installed in the holder.
IMAGE: http://i89.photobucket.com/albums/k220/jeffreybehr/Hitech%20100mm%20Slide-In%20Filter%20System/2013May01_holderbacksidewringinstld_1200w_zpsbcbb44d7.jpg
IMAGE LINK: http://s89.photobucket​.com …200w_zpsbcbb44d​7.jpg.html  (external link)
The ring can be installed on the lens and then the holder slid onto and tightened onto the ring, or the ring can be kept clamped in the holder and the combined assembly screwed onto the lens.
The screws holding the holderclips onto the holder plate can be installed pointing forward or rearward, but pointed forward they intrude into the image at 22mm and shorter with my 17-40.
IMAGE: http://i89.photobucket.com/albums/k220/jeffreybehr/Hitech%20100mm%20Slide-In%20Filter%20System/2013May01_holderfronttriplesliders_1200w_zpsc2e8f465.jpg
IMAGE LINK: http://s89.photobucket​.com …200w_zpsc2e8f46​5.jpg.html  (external link)
Here's the front of the holder with 2 holderclips installed, screws pointed rearward, and one filter started into the holder.
IMAGE: http://i89.photobucket.com/albums/k220/jeffreybehr/Hitech%20100mm%20Slide-In%20Filter%20System/2013May01_holderfrontdoublesliderswithfilter_1200w_zpsd4e5df97.jpg
IMAGE LINK: http://s89.photobucket​.com …200w_zpsd4e5df9​7.jpg.html  (external link)
Here's what it looks like on the 17-40.
IMAGE: http://i89.photobucket.com/albums/k220/jeffreybehr/Hitech%20100mm%20Slide-In%20Filter%20System/2013May01_installedon17-401200w_zpsee802dd3.jpg
IMAGE LINK: http://s89.photobucket​.com …200w_zpsee802dd​3.jpg.html  (external link)
This stuff appears to be made very well and plenty strongly, and the extra screws and nuts are appreciated, as they're small and easily lost in the field if you chose to change the holder's configuration.
I hope this helps other novices at slide-in filter systems.
Fuji X-H2 w/SmallRig all-around L-plate.. Fugi lenses in 10-24/4, 16-55/2.8, 70-200, and 33/1.4, Canon TS-Es in 24/3.5 and 50/2.8, and Viltrox 75/1.2.. Gitzo GT-3533S Systematic tripod with leveler and Rogeti geared head.
IShootThings
I thought I was special.......
May 04, 2013 12:00 |  #2
Thanks, this is very helpful!
Canon 5D3, Canon XTI (IR converted), 24-70 f2.8L, 16-35 f4L, 50 1.4, 70-200 f2.8L, 100 2.8 macro, 430 ex & 580 exII speedlights.
irishman
May 06, 2013 00:27 |  #3
If you can't put the filter in the first slot, wouldn't that cause light leak on long exposures?
6D, G9, Sigma 50 1.4, Sigma 15mm Fisheye, Sigma 50 2.8 macro, Nikon 14-24G 2.8, Canon 16-35 2.8 II, Canon 24-105 f/4 IS, Canon 70-200 2.8 IS, tripod, lights, other stuff.
gremlin75
Jun 17, 2013 19:56 |  #4
jeffreybehr wrote in post #15889334 (external link)
The first slot will hold a filter, you just have it assembled incorrectly. The spacer you have on the bottom is only to be used if you are using a 4mm think filter such as HiTech's 10 stop ND. any other ND filter should only be 2mm thick. Take out the spacer and the first slot will hold a filter properly and you will not get any light leak.
irishman wrote in post #15901748 (external link)
Yes the way it is set up light leak would be an issue. However like I said above the filter holder is just not set up properly the way it's pictured unless he was to use a 4mm think ND filter like HiTech 10 stop
jeffreybehr
Joined Apr 2013
Jun 18, 2013 12:21 |  #5
gremlin75 wrote in post #16040467 (external link)
TYVM, Gremlin. That's the way it was factory assembled, and I didn't find anything about that in the instructions...or at least I don't remember seeing anything. :oops:
gremlin75
Jun 18, 2013 16:03 |  #6
jeffreybehr wrote in post #16042384 (external link)
I wouldn't be surprised if the HiTech holder didn't come with any instructions. Which is just stupid to me with a modular system like it. Wothout instructions most users may not know what each part of the system if for espically if they ship it out with the spacer already installed!
3,200 views & 0 likes for this thread, 4 members have posted to it.
1608 guests, 142 members online
