Some great shots there guys!
OK... So as promised here's a random selection of pics from slightly different angles:
From the sidelines, about 20 yards down from the half-way line at 420mm (300mm + 1.4x)...
| IMAGE IS A REDIRECT OR MISSING! HTTP response: 404 | MIME changed to 'text/html' | Byte size: ZERO |
Again from the sidelines at 420mm, right on the half-way line. This might also be one good example of why it's not always a good idea to zoom out...
Something in the goal area, taken from behind the goal-line just outside the 18-yard box with the 70-200mm...
Again from behind the goal-line at 600mm (300mm +2x), a celebration at the far end of the pitch...
From the same game and the same position at 420mm...
From adjacent to the corner flag at 420mm, diagonally across the pitch...
Another reason I often like to shoot from the sidelines, the manager shot..
Also, bear in mind that when players celebrate a goal they often run
away from the visiting fans behind the goal
Like I said, just a random selection of pics. I think I favour the sideline view as it opens up the opportunites, particularly if you have access to 300mm+ glass. It's just a matter of style I suppose... but I've also been sat behind the goal for a full 45 minutes and not managed a half-decent pic because all the action has been at the other end
Did I mention that the sideline view makes for great shots of the goalie as well (at 300mm)?...
IMAGE:
http://www.tgsphoto.co.uk/forum_images/ooo001.JPGIn all honesty, football provides stacks of great images from the sidelines, from the corners or from behind the goals... Just remember to keep both eyes open
---- Gavin
