Just curious what most people are using for settings when sharpening in lightroom.
Sgt. Senior Member More info | May 02, 2013 14:44 | #1 Just curious what most people are using for settings when sharpening in lightroom. Iain
zerovision Goldmember 1,204 posts Likes: 3 Joined Aug 2008 Location: Dallas/Ft Worth area More info | May 02, 2013 14:52 | #2 I start with bumping one notch, but that doesn't work every time.
PixelMagic Cream of the Crop 5,546 posts Likes: 6 Joined Nov 2007 Location: Racine, WI More info | May 02, 2013 14:53 | #3 Not sure what you mean... there are at least three ways to sharpen in Lightroom and each serves a different purpose.
May 02, 2013 16:06 | #4 What do you generally set the slider to in the develop module under sharpening. Iain
zerovision Goldmember 1,204 posts Likes: 3 Joined Aug 2008 Location: Dallas/Ft Worth area More info | May 02, 2013 16:19 | #5 General sharpening is the moving up one notch. This is done on almost every image. If the eyes are not sharp after that then I will go into the and sometimes I can max out the sharpen slider and it will have just a slight effect. I can do this a couple times without it being too harsh, but there is a limit.
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | May 02, 2013 17:11 | #6 The Detail panel sharpening has four parameters (four sliders) and they are interrelated, so a simple answer (like moving up a notch - how much is a notch?) which relates only to the first slider would be inadequate and misleading. Increasing Radius, for instance, might necessitate decreasing Amount. Increasing the Mask will almost always need a higher Amount. Not only that, but you also need to consider that NR strongly affects sharpness and so does Clarity to a certain extent. Of course you could just use the two sharpening presets supplied by Adobe - one for landscapes and one for portraits - but without understanding what each slider does and why those presets are the way they are, your sharpening will be very limited and pretty much "hit or miss". I suggest you read/watch some tutorials. These two might be a good place to start: Elie / אלי
PixelMagic Cream of the Crop 5,546 posts Likes: 6 Joined Nov 2007 Location: Racine, WI More info | May 02, 2013 17:15 | #7 I rarely ever go above 40 using Sharpening in the Details panel. You have to realize that the panel is primarily intended for Capture Sharpening, to correct for softness introduced by your camera's anti-aliasing filter. That also means that the Sharpening slider is used in conjunction with the Masking and Details slider to "dampen" or control the amount of sharpening applied to edge details. Sgt. wrote in post #15891359 What do you generally set the slider to in the develop module under sharpening. I am on my phone right now, and I cant remember the name under the slider. I usually bump to around 70. But I saw a post somebody had put up a screenshot and they had it at 120. I thought that was kind of high. So I thought I would ask what people are setting them to. I know each photo can be different, just a general concensus. As to what people are doing. I hope you understand better now. Thank you
Scrumhalf Cream of the Crop More info | May 02, 2013 17:20 | #8 This youtube video was very useful in understanding how to do sharpening, especially the functioning of the masking slider. Sam
NCHANT Goldmember More info | May 02, 2013 18:56 | #9 I have a default setting I use on every image, which seems to work pretty good. 6D x 2 | TM SP 35mm ƒ1.4 | 50mm ƒ1.8 | 85mm ƒ1.8 | 24-105mm ƒ4L USM | 135mm ƒ2L | 200mm ƒ2.8L II | 17-40mm ƒ4L | Sy 24mm ƒ1.4 | Sy XP 14mm ƒ2.4 Flickr
May 02, 2013 22:29 | #10 It really depends on the subject matter and the pixel density of your sensor along with the degree of ISO noise in the image. The radius relates to the sensor density, on big sensors like a 5DIII you can get away with 1.2-1.3, for a 1D4 1-1.1. Amount I go as high as 45 for architectural stuff, low to mid 20's for people or busy backgrounds. The masking slider will put the sharpening on edges more than midtones and you want to bump it up for high ISO noise, mid 80-mid 90s for ISOs 6400. Hold down alt-shift while adjusting masking to see the effect. Details slider will bring up detal via micro contrast, but does it at the expense of also magnifying ISO noise. I don't use it very often unless it is for low iso architectural stuff. There is no one value, it all depends on the camera, subject matter, and ISO noise. Gear List
May 02, 2013 22:50 | #11 I don't think I've ever sharpened anything in Lightroom. I sharpen at standard/normal when outputting to jpeg. And I'll sharpen before printing at home. Maybe I should try. Retouching
morph2_7 Goldmember 1,112 posts Joined Sep 2012 Location: Los Angeles More info | May 03, 2013 00:36 | #12 Scrumhalf wrote in post #15891598 This youtube video was very useful in understanding how to do sharpening, especially the functioning of the masking slider. http://www.youtube.com …TA5E_Am26x8dl4tRRK1xjoAuf Thank you. That is very useful. Sgt. wrote in post #15891095 Just curious what most people are using for settings when sharpening in lightroom. When it comes to sharpening, I normally start off with predefined Sharpen presets either for landscapes or portrait. Then I adjust the amount slider, usually between 40 to 50. I rarely go above 50. That's pretty much it. I never touch other sliders (Radius, Detail, Masking) in sharpening panel simply because I don't know what they do. Now that I've watched the above video, I'm going to try adjusting them.
May 03, 2013 03:12 | #13 Thanks for the replies. Iain
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | May 03, 2013 06:00 | #14 bsmotril wrote in post #15892441 It really depends on the subject matter and the pixel density of your sensor along with the degree of ISO noise in the image. The radius relates to the sensor density, on big sensors like a 5DIII you can get away with 1.2-1.3, for a 1D4 1-1.1. Sensor density has nothing to do with sensor size. The 5D2 has exactly the same sensel density as the 30D, despite the fact that the sensor is larger - 2.56 times the area of the 30D crop sensor. The 5D3 has slightly higher density, roughly in the middle between the 30D and the 40D. Moreover, "density" means the number of sensels to a spatial unit, an inch. But digital images have no inches and no density; they acquire physical size only in a display medium. When viewing a monitor you are seeing screen pixels and their density. Only at 100% zoom does one screen pixel portray one image pixel, but that does not change the fact that what you see is a physical lcd pixel with a fixed size and a density that is usually 100 pixel per inch. The masking slider will put the sharpening on edges more than midtones Edges and midtones are not opposites. There can be strong edges that are within the middle tone range. Masking decreases or even eliminates the sharpening on low frequency edges (edges with a small degree of tonal difference from one side of the edge to the other) while retaining it on high frequency edges. Elie / אלי
PixelMagic Cream of the Crop 5,546 posts Likes: 6 Joined Nov 2007 Location: Racine, WI More info | May 03, 2013 07:58 | #15 I watched that video twice because I was quite surprised at the amount of misinformation presented as fact. The presenter several claims that are demonstrably false: Scrumhalf wrote in post #15891598 This youtube video was very useful in understanding how to do sharpening, especially the functioning of the masking slider. http://www.youtube.com …TA5E_Am26x8dl4tRRK1xjoAuf
| Latest registered member is semonsters 922 guests, 118 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
