Thread started 02 May 2013 (Thursday) 22:21
2nd attempt at Brenizer.....
Guitartists
May 02, 2013 22:21 |  #1
I think this one went better. Used my 28-90mm 5.6 set to 90mm. What do you think?? 48 shots used.
HTTP response: 403 | MIME changed to 'text/plain'
"Photography has no rules. It is not a sport. It is the result which counts, no matter how it was achieved." ~ Bill Brandt
Gear: Canon EOS Rebel T3 and some lenses and what-not :p ~~~ See my Artwork & Photography @ http://www.artwanted.c​om/guitartistsexternal link
Flo
Gimmie Some Lovin
May 02, 2013 22:26 |  #2
Not getting the concept for this at all.sorry:(
Guitartists
May 02, 2013 22:27 |  #3
The concept was my daughter was the only one willing to hold still long enough for me to get the shots....but wanted to be a butt and cover her face ;) I just want to know if the technique worked ;)
Aleness
May 03, 2013 01:35 |  #4
I'm not sure the technique worked, since your main subject occupies most of the frame and there is no feeling of separation and intimacy.
Bunnies will rule the world!
Websiteexternal link | Gear List & Feedback
Guitartists
May 03, 2013 05:11 |  #5
ok...I get what you are saying :( Guess I will have to wait until I get the right lens then :P Was hoping I could use what i have.... but I just can't get the right depth of field AND distance that I need to make it work :P grumble grumble
cpam.pix
Joined Apr 2011
May 03, 2013 06:16 |  #6
Guitartists wrote in post #15892436 (external link)
Her technique worked. Her face is covered. ;)
I feel your pain. I live it, too.
1D-III with stuff to stick on it:
70-200L, 28-70L, 24-105L, 300L, 50, 10-17 fish, 2.0x TC
Image editing OK, encouraged, and expected. Thank you for helping me learn!
Flo
Gimmie Some Lovin
May 03, 2013 10:02 as a reply to  @ cpam.pix's post |  #7
http://blog.buiphotos.​com …xplained-with-directions/ (external link)
With video!:D
gonzogolf
dumb remark memorialized
Gallery: 559 photos
May 03, 2013 10:09 |  #8
I'm just not seeing the benefit of using that technique for this shot. The sky is going to be OOF anyway, and ditto for the grass. If you were intentionally blurring background detail that was actually present in the image it might be worth the effort.
Guitartists
May 03, 2013 15:12 |  #9
gonzogolf wrote in post #15893649 (external link)
Well, before heading out to find worthy subject matter and spending the time it takes to put all of the shots together effectively.... I was just doing test shots to see if I can even get the effect with the one of the lenses I already own....since I don't have one of those nifty 85mm 1.8 lenses. I tried with my nifty fifty....but the distortion was too much :(
Guitartists
May 03, 2013 15:13 |  #10
Yeah, that was the page I had found a couple weeks ago. Just trying to make it work with what I got ;)
Guitartists
May 03, 2013 15:44 |  #11
Here's another one (goats)from that day using my 28-90.... but you can see that I was too far away and it doesn't have the right depth of field.
And here is an earlier one (grave) that I think would be good if there wasn't so much distortion :( nifty fifty used.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/05/1/LQ_647615.jpg
Image hosted by forum (647615) © Guitartists [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/05/1/LQ_647616.jpg
Image hosted by forum (647616) © Guitartists [SHARE LINK]
Guitartists
May 03, 2013 15:45 |  #12
So maybe with the 28-90.... split the difference in distance from the subject between the one of my daughter and the one of the goats??
Guitartists
May 03, 2013 15:46 |  #13
A note.... I keep forgetting to set my white balance before starting the shoot :P Gotta commit that to memory :P
gonzogolf
Gallery: 559 photos
May 03, 2013 16:06 |  #14
Guitartists wrote in post #15894718 (external link)
The effect is greatest when you use a longer lens and work relatively close maximizing the shallow depth of field from that combo, then stitch out images to replicate the field of view of a wider lens. Using a 50 would work if you are very close but its really better with longer lenses. You have to fix a white balance and put your exposure in manual so the images all have the same base parameters.
Guitartists
May 03, 2013 16:24 |  #15
Here that grave one is finished as best as I could
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/05/1/LQ_647627.jpg
Image hosted by forum (647627) © Guitartists [SHARE LINK]
2,241 views & 0 likes for this thread, 8 members have posted to it and it is followed by 2 members.
554 guests, 120 members online
