Thread started 03 May 2013 (Friday) 03:11
Lens calibration Q
0.0f
Joined Apr 2011
May 03, 2013 03:11 |  #1
Can a L-series lens be calibrated to different bodies, e.g if you own two bodies can you have the same lens calibrated to the two bodies? I was under the impression that a lens can only be calibrated to one body at a time.
EOS 5D MK3 - 24-70 MK2
Scatterbrained
Gallery: 263 photos
Best ofs: 12
May 03, 2013 03:40 |  #2
IIRC the adjustments are stored in the body so I can't imagine why you wouldn't be able to, assuming the bodies have microadjust.
500px (external link)
1x (external link)
instagram (external link)
chrismarriott66
Gallery: 14 photos
Joined Jan 2012
May 03, 2013 04:22 |  #3
^ Yes this is correct - you can adjust different amounts for each lens on each body, as both the camera bodies and the lenses have individual fluctuations. For example, you may need to be +X on one body and -Y on another... However, I don't think you can send a lens off for calibration to two bodies, but I might be wrong.
Canon (or whichever manufacturer) calibrate a lens to the body if you send both off, OR they calibrate the lens to one of their own bodies that ensures the lens is within acceptable tolerances (if you don't send a body with the lens).
That's my understanding anyway, but someone else may know more :)
Chris Marriott Photography (external link)| Facebook (external link)
Complete Gear | 1ds iii | 5d iii | 50d | EF 16-35 f2.8 L USM ii | EF 24-70 f2.8 L USM | Σ 70-200 f2.8 ii EX DG HSM | Σ 35mm f1.4 Art | EF 50mm f1.4 USM | EF 85mm f1.8 USM | EF 85mm f1.2 L USM ii | 600EX-RT | 580EX ii | 430EX ii | YN622Cs |
Canon ­ Bob
May 03, 2013 05:24 as a reply to  @ chrismarriott66's post |  #4
Lens calibration is just that and it entails sending the lens and body to a Canon centre (or an approved one)
AF micro adjust is an "adjustment" (you do this yourself) where an offset value is stored in the camera's memory.....each body can be independantly optimised for the lens.
Bob
1Dx2 (2), 5DSR, 1Ds3, 1D4, 5D2(590nm), 5D2(720nm) EF600 EF400 EF300-II EF300 EF200 EF200-II EF180L EF135L EF100 EF85-II EF50L TS-E17/4 TS-E24L-II TS-E45 TS-E90 MP-E65 EF70-200-II EF24-70/2.8-II EF16-35/4 EF8-15/4 EF11-24/4 Zeiss 15/2.8 21/2.8 25/2 28/2 35/1.4 35/2 50/2 85/1.4 100/2 135/2 T/C's L-SC & a WIFE!
Bill ­ Emmett
Joined May 2012
May 05, 2013 15:59 |  #5
You can buy a software called FoCal. Get the Pro level, or the most expensive version. This version will make the micro adjustments to your camera automatically. The program will also tell you the optimum lens zoom value, called sweet spot. I have bought and used FoCal on my 50D and Canon lenses and Tamron lenses, it has improved the AF with every lens in my bag, including my "L" glass.
New Canon EOS 5D Mark IV, Canon EOS 7D Mark II, Canon EOS 50D, Canon 7D Classic, Canon 6D, Canon EF 70-200 f4L USM with IS, Canon 40mm pancake, Canon EF 50mm 1.8, Canon EF-S 10-22mm wide angle, Canon EF-S 18-135 IS STM, Canon EF 100mm 2.8L USM Macro, Tamron 18-270mm Dii VC, Tamron SP 150-600mm VC, Tamron SP 24-70mm f2.8 VC USM, Canon EF 16-35 f2.8L II USM, Tamron 2X Tele-Extender, 1.4 Tele-extender
827 views & 0 likes for this thread
Lens calibration Q
Latest registered member is m.nobles
839 guests, 187 members online
