How do you preserve the Aspect Ratio when cropping in CS3?
Such a basic question and I've searched the threads and can't find the answer. Your help is much appreciated, thank you.
May 03, 2013 13:40 | #1 |
CyberDyneSystems Admin (type T-2000) More info | May 03, 2013 13:48 | #2 When you select the crop tool, in the border of the main window, upper left hand side closest to the image, there are spaces to input "Width" and "Height" GEAR LIST
RenéDamkot Cream of the Crop 39,856 posts Likes: 8 Joined Feb 2005 Location: enschede, netherlands More info | May 04, 2013 10:56 | #3 Either that, or crop around the entire image, then press shift while adjusting the crop… "I think the idea of art kills creativity" - Douglas Adams
CyberDyneSystems Admin (type T-2000) More info | May 04, 2013 11:01 | #4 Hah, never knew that one! Thanks for the short cut. GEAR LIST
Thanks for the tips. I don't know the current aspect ratio so I'm having problems with using the Front Image method. Rene's tip is a whole lot simpler and also allows a variable method that doesn't matter what the size or aspect ratio is and allows me to continuously adjust it to taste which is what I'm looking for. Love it, thank you... "When I shoot something I use a Canon!"
BigAl007 Cream of the Crop 8,120 posts Gallery: 556 photos Best ofs: 1 Likes: 1682 Joined Dec 2010 Location: Repps cum Bastwick, Gt Yarmouth, Norfolk, UK. More info | May 04, 2013 12:54 | #6 Well if you have a standard uncropped image from a DSLR then the aspect ratio is 3:2, unless it is Olympus which is 4:3. I think just about all compact & PnS cameras along with most of the new MLSC's are also 4:3 ratio. Some PnS cameras also offer other ratios such as 16:9 but that is usually done by cropping the std 4:3 image in camera.
Lowner "I'm the original idiot" 12,924 posts Likes: 18 Joined Jul 2007 Location: Salisbury, UK. More info | May 04, 2013 12:59 | #7 BushWacker wrote in post #15897009 Thanks for the tips. I don't know the current aspect ratio so I'm having problems with using the Front Image method. Rene's tip is a whole lot simpler and also allows a variable method that doesn't matter what the size or aspect ratio is and allows me to continuously adjust it to taste which is what I'm looking for. Love it, thank you... Not sure how its possible not to know the aspect ratio. The image is what it is, that's the aspect ratio. So for example 8000 pixels x 5000 pixels is 8 x 5. Or in inches 12 x 8 inches is 3 x 2. Richard
Damo77 Goldmember 4,699 posts Likes: 115 Joined Apr 2007 Location: Brisbane, Australia More info | May 04, 2013 15:50 | #8 |
CyberDyneSystems Admin (type T-2000) More info | May 04, 2013 15:51 | #9 Clicking front image immediately tells you in the same boxes what the ratio is.. you don't need to know. it tells you and then adjusts at the same ratio. GEAR LIST
Damo77 Goldmember 4,699 posts Likes: 115 Joined Apr 2007 Location: Brisbane, Australia More info | May 04, 2013 16:42 | #10
May 05, 2013 01:07 | #11 So the picture will fit into the frame properly. Damo77 wrote in post #15897529 Why would you want to crop to the same aspect ratio? "When I shoot something I use a Canon!"
May 05, 2013 01:09 | #12 |
Damo77 Goldmember 4,699 posts Likes: 115 Joined Apr 2007 Location: Brisbane, Australia More info | May 05, 2013 01:21 | #13 BushWacker wrote in post #15898752 So the picture will fit into the frame properly. If you're cropping for print, you should crop to the exact print size. The fact that it's the same shape as your camera is completely coincidental, and has no relevance at all.
May 05, 2013 22:50 | #14 Understood, thank you... Damo77 wrote in post #15898777 If you're cropping for print, you should crop to the exact print size. The fact that it's the same shape as your camera is completely coincidental, and has no relevance at all. "When I shoot something I use a Canon!"
| Latest registered member was a spammer, and banned as such! 2531 guests, 94 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
