Thread started 04 May 2013 (Saturday) 16:31
Protection filter + lee grad filters
AndyWahl
Joined Nov 2012
May 04, 2013 16:31 |  #1
Maybe a noob question but I was wondering if you can use the cheap 5 dollar tiffen UV protection filters in combination with the square lee filters.
On their site it shows that it has an adapter ring to connect the filter holder to the lens so Im guessing you cannot have a protection filter on at the same time?
Im looking for some kind of lens protection that I dont have to put on and take off every time I want to use the lee filters is this even possible or what are the other options?
http://andywahl.wordpr​ess.com (external link) l Flickr l (external link) 5∞ (external link) l Instagram (external link)
Scatterbrained
Gallery: 267 photos
Best ofs: 12
May 04, 2013 16:39 |  #2
You can, but I'd recommend taking that Tiffen filter off anyhow as they've been known to hurt IQ.
I normally will have a CPL on the lens and then attach my filter holder to it's outside threads. Unless your UV filter is a thin mount it should have a threaded front for stacking filters.
500px (external link)
1x (external link)
instagram (external link)
RobDickinson
Gallery: 14 photos
May 04, 2013 16:47 |  #3
Just leave the protection filter off. They dont actually protect anything and often cause more damage.
www.HeroWorkshops.com (external link) - www.rjd.co.nz (external link) - www.zarphag.com (external link)
Gear: A7r, 6D, Irix 15mmf2.4 , canon 16-35f4L, Canon 24mm TS-E f3.5 mk2, Sigma 50mm art, 70-200f2.8L, 400L. Lee filters, iOptron IPano, Emotimo TB3, Markins, Feisol, Novoflex, Sirui. etc.
jimewall
May 04, 2013 16:49 |  #4
AndyWahl wrote in post #15897647 (external link)
You will get a lot of people on this site that will say skip any filter as a protector. If you do choose to use a protective filter, almost nobody will suggest a cheapo filter, as it will make adversely affect the IQ of a lens. If you are going to use a protective filter get a top filter like the higher end Hoya or B+W.
As for the Lee filter system, there are adapter rings you get for the size filter thread, then the filter holder goes on the adapter. So as long your filter has threads (most do, but some thin versions do not) and everything is not so far forward that you get too much vignetting - the system will work with a protective filter.
Thanks for Reading & Good Luck - Jim
GEAR
AndyWahl
Joined Nov 2012
May 04, 2013 17:05 |  #5
RobDickinson wrote in post #15897687 (external link)
Damage how?
I just cant fathom getting a scratch or chip from a rock or debris on a $2000 lens as I will be shooting things such as cars or action sports or some kind of sand while doing landscape photos
Scott ­ M
Gallery: 111 photos
May 04, 2013 17:13 |  #6
AndyWahl wrote in post #15897730 (external link)
Damage how?
So you would instead put a cheap, low quality $5 filter on a $2,000 lens? That defeats the purpose of buying a high quality lens.
Photo Gallery (external link)
Scatterbrained
Gallery: 267 photos
Best ofs: 12
May 04, 2013 17:14 |  #7
Damage how?
The UV filter will break faster than your lens will chip, and when it does it will scratch the bejeebus out of your lens. http://www.youtube.com …er_embedded&v=v​zOLbMPe0u8 (external link)
1x (external link)
RobDickinson
Gallery: 14 photos
May 04, 2013 17:39 |  #8
Yes. FIlters break much easier than lenses and that broken sharp glass can scratch your lens. Also the damaged filter thread can get stuck on your lens requiring a tricky removal that can cause further damage.
Hogloff
Joined Apr 2003
May 04, 2013 21:06 |  #9
RobDickinson wrote in post #15897810 (external link)
There are definite conditions under which a protection filter is useful. I shoot a lot of rodeos up close and rocks are flying when the animals are close. I've broken a few UV filters in my time by flying rocks. Guaranteed these rocks would have at the very least put a nick into my lens and at the worst, cracked the lens.
I also use a UV filter in the desert with a lot of fine blowing sand that gets stuck to the filter. I quickly replace the UV filter with another and keep on shooting without having to carefully clean a front element. The same goes for shooting at the ocean with a lot of blowing sea mist. Just change the UV filter and keep on shooting.
Lots of uses for the UV filter.
tomme
May 05, 2013 01:05 as a reply to  @ Hogloff's post |  #10
wow!, 5 dollar filter infront of a 2000 dollar lense! Its like : your got yourself a new ferrai with a V12 engine, you rip out the engine and replace It with a ford fiesta 1.2L engine :D
RobDickinson
Gallery: 14 photos
May 05, 2013 01:28 |  #11
Hogloff wrote in post #15898278 (external link)
Yes,I'll admit there are some times when you may want to use a filter. Make sure its a decent one though!
DreDaze
Gallery: 49 photos
May 05, 2013 01:34 |  #12
but let's be honest...you can't guarantee that the rocks would effect the front element at all...
show me one instance where a rock did damage to a front element...and not a dropped lens...but an actual rock hitting it...or sand hitting it, and causing a scratch, chip, crack...anything...
protection filters are for peace of mind...they don't guarantee anything...but they make people feel better...if you need one, get a good one...don't get a cheap one
Andre or Dre
gear list
hollis_f
May 05, 2013 08:04 |  #13
DreDaze wrote in post #15898804 (external link)
Actually, I thought they were for generting a living for camera shop salesmen -
"OK, sir has made an excellent decision to purchase the $2000 super-dooper lens (thinks: On which I make $10 profit). Now sir really needs to protect his investment with a good quality protective filter. This one is only $50 and, as sir can see, is digital! (Yeah, that should be $45 profit for me.)"
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
Hogloff
Joined Apr 2003
May 05, 2013 09:52 |  #14
A rock that cracks a filter would definitely at the very least scratch the front element. I cannot show you since I used a protection filter in these conditions to actually protect the lens.
I've seen fine scratches on many lens most likely caused by trying to clean the glass when there were fine dust or even sand on the glass.
If you don't shoot in harsh environments then you don't need a protection filter. If you do shoot in environments that can cause damage, I suggest using them. Of course each has to determine their own risk tolerance.
blanex1
Joined Nov 2012
May 05, 2013 11:52 |  #15
you ever seen lens for sale on this sight!some of them have a nick or scuff marks on there front element ,gess why,no lens filter,if you keep the filer clean they do not degrade the photo in any way.
canon 7d bg-e7 5d-mk3 1d-mk3 24-105-L 17-40 L 35/1.4 85/1.8 yougnuo 565 ex 580 ex and lots of other canon stuff.canon 70-200 2.8 L
1,936 views & 0 likes for this thread, 10 members have posted to it.
587 guests, 148 members online
