Thread started 06 May 2013 (Monday) 08:07
7D sensor issue at high ISO
sporadic
Gallery: 55 photos
May 06, 2013 08:07 |  #1
I was at the local aquarium yesterday taking a few shots and noticed this issue in post. I only noticed the problem in my ISO 3200+ photos. About 3/8 across the frame from the left, there is a vertical line of pixels which aren't exposing properly. The issue is more prevalent in the lower end of the spectrum / underexposed areas and can been seen best above the eagle's head on the tree. This was shot was at ISO3200 in RAW and processed in LR. The camera was purchased from Adorama back in October 2009. Any guesstimates on what Canon would charge me to fix this or what actions I should take?
thanks,
-shelby
IMAGE: http://farm9.staticflickr.com/8543/8714246840_3a81fed7a5_b.jpg
Fuji X-T1 | X-T2 | 35/1.4 | 10-24 | 18-55 | 55-200 | 50-140 | Rokinon 8/2.8II Fisheye | Rokinon 12/2
7D | 300/4 L IS
aliengin
Joined Mar 2011
May 06, 2013 08:23 |  #2
Is this what they call banding issue? I am not sure but I think I read something like this before.
Ali Engin Photography (external link)
sporadic
Gallery: 55 photos
May 06, 2013 08:32 |  #3
aliengin wrote in post #15902406 (external link)
The banding issue I believe is repetitive vertical bands (when in landscape orientation) in the shaded areas. This is a 1 pixel wide line that stays in the same sensor location.
7D | 300/4 L IS
MakisM1
Gallery: 20 photos
Joined Dec 2011
May 06, 2013 08:33 |  #4
May I suggest you post a 100% crop of the photo? If you want to confirm whether it is a line of dead pixels... If you post a downsized photo (to 1024) you are averaging 4 pixel values.
Gerry
Canon 5D MkIII/Canon 60D/Canon EF-S 18-200/Canon EF 24-70L USM II/Canon EF 70-200L 2.8 USM II/Canon EF 50 f1.8 II/Σ 8-16/ 430 EXII
TeamSpeed
01010100 01010011
Gallery: 94 photos
Joined May 2002
May 06, 2013 08:36 |  #5
If you have a row of pixels out, you should see this at all ISOs, and I would think it would be repeatable. Definitely do a 100% crop and post it up though. Have you tried other CF cards?
sporadic
Gallery: 55 photos
May 06, 2013 08:47 |  #6
I don't have access to the original right now, but will get a 100% crop up tonight when I get home. I'm pretty sure it was 1 pixel wide last night when I processed it though. Actually, this is a newer CF card (around 500 shots so far) but I've only noticed it on ISO3200+ photos. I don't usually go past 1600, but will check my archives tonight to see if I can find evidence from older CF cards and firmware.
7D | 300/4 L IS
sporadic
Gallery: 55 photos
May 06, 2013 08:57 |  #7
Here's a higher resolution one on Flickr (external link), however Facebook has already done it damage to it as I pulled it from my page. Will get a full res crop up tonight. Thanks!
7D | 300/4 L IS
MakisM1
Gallery: 20 photos
Joined Dec 2011
May 06, 2013 08:58 |  #8
You might wish to take a light photo and a dark one (cap on).
Gerry
sporadic
Gallery: 55 photos
May 06, 2013 17:39 |  #9
Here are two of the eagle. No processing, just cropped 100% and coversion to jpg. Will try other tests later this evening when I get time.
IMAGE: http://farm8.staticflickr.com/7444/8716028708_5414f98e9c_o.jpg
IMAGE: http://farm8.staticflickr.com/7458/8714909155_336fcec243_o.jpg
7D | 300/4 L IS
CyberDyneSystems
Admin (type T-2000)
Gallery: 152 photos
Joined Apr 2003
May 06, 2013 17:46 |  #10
That's really weird that it is invisible or non existent in the white feathers.
This is in more than one photo?
CDS' HOT LINKS
jwcdds
Gallery: 1640 photos
Best ofs: 5
Joined Aug 2004
May 06, 2013 18:38 |  #11
Hehe.. I've seen that before.
Your sensor has gone bad. My 1st copy of the 7D was just like this after 2 weeks of usage, when I bought it in 2009. It's as if a row of pixels had died or got stuck.
Adorama send me a replacement. But this is a sensor issue, unfortunately.
Julian
sporadic
Gallery: 55 photos
May 06, 2013 19:11 |  #12
I just went back through my archives and it looks like it started at ISO6400 back in 2010.... ugh. I would've normally deleted these but good thing for being lazy! I could only find two photos from that year which had it at 6400 and none at 3200. Here's the best example I could find. Same location and very pronounced red. First is processed with the 2003 settings in LR, 2nd with 2012 settings.
IMAGE: http://farm8.staticflickr.com/7408/8715108103_7c64fb9352_b.jpg
IMAGE LINK: http://www.flickr.com …3/sizes/l/in/ph​otostream/  (external link)
IMAGE: http://farm8.staticflickr.com/7307/8715107803_33ea2ffc80_b.jpg
7D | 300/4 L IS
sporadic
Gallery: 55 photos
May 06, 2013 19:18 |  #13
Just checked my 2012 photos as well. Highest ISO that year was 3200 with 100 photos, all of which are properly exposed and don't exhibit the issue. Seems constrained to underexposed areas of the photo and only at high ISO 3200+. Not a single hint of issues in any of my ISO1600 shots, even in the underexposed areas. I'll try some cap tests when I get a chance. Thanks for the feedback.
7D | 300/4 L IS
MakisM1
Gallery: 20 photos
Joined Dec 2011
May 06, 2013 19:31 |  #14
Normally you would see either dead pixels (black) or stuck pixels (bright). I guess there is no reason why they wouldn't get 'stuck' in an intermediate value and 'wake up' above a certain threshold...
Just thinking aloud...
Gerry
sporadic
Gallery: 55 photos
May 06, 2013 19:53 |  #15
Just snapped a dozen dark cap shots at ISO3200 and 6400. Only showed on a few at 6400 this time. The rest you could barely tell. Below is the best example. Click for the full size orignal.
IMAGE: http://farm8.staticflickr.com/7315/8716320494_dddd132592_b.jpg
IMAGE LINK: http://www.flickr.com …4/sizes/l/in/ph​otostream/  (external link)
7D | 300/4 L IS
2,452 views & 0 likes for this thread
Latest registered member is Bogdan12
706 guests, 257 members online
