Thread started 07 May 2013 (Tuesday) 04:13
foCal question
jaomul
Joined Apr 2011
May 07, 2013 04:13 |  #1
Sorry if this is not the correct section, but i figured it is the body that gets adjusted so maybe it is ok here. I see a few references to foCal software for micr adjusting lenses. I considered buying this. Question for anyone who has used this-Is it worthwhile and if so which version would be best for an enthusiast as opposed to pro. Thanks
Olympus EM5,Nikon d7200,
Olympus 12-50mm, 40-150mm,17mm f2.8,Nikon 50mm F1.8, Tamron 90mm vc, 18-105mmVR, Sigma 18-35 f1.8
goldboughtrue
May 07, 2013 04:41 |  #2
I downloaded it when it was free a couple years ago and none of my lenses needed any adjustment on my 5D II. If you think one or some of your lenses are way off, you could consider it. Or you could run your own test. Angle the camera at 45 degrees with some printed material (preferably horizontal lines) and then see if the lens is off.
If you can't see that what you've focused on is really out of focus, I wouldn't worry about it.
http://www.pbase.com/g​oldbough (external link)
5D II, Canon 100 macro, Canon 70-200 f/4L, Canon 24-105 L, Canon TS-E 45, Sigma Art 35mm f/1.4
hollis_f
May 07, 2013 05:07 |  #3
jaomul wrote in post #15905828 (external link)
Actually, it's probably better for an enthusiast than a pro. A pro realises that time=money and that the time spent playing around with Micro Focus Adjustment is time spent not earning; for a result that is not likely to make any discernable difference to their final images.
Enthusiasts, on the other hand, tend to enjoy playing around with their gear and investigating all the possible ways of optimising performance. You'll read loads of people saying how vitally important MFA is, yet everybody managed without it for many, many years. Even when the 40D was released (after Canon had already produced MFA for the 1D) nobody complained about the lack of MFA.
So, what sort of difference can you expect? Well, it depends on whether or not your body or any of your lenses are almost out of spec. Here's what FoCal Pro produced for my Tokina 11-16. These are 100% crops at MFA values of -3, +1 and +4. As you can see, the difference is remarkable - remarkably small.
IMAGE: http://www.frankhollis.com/temp/AFMA.jpg
What I suggest you do it to shoot a well-lit, flat target (not 45º - that will not work) that fills the viewfinder (a cereal packet is a good target). Put your camera on a tripod and take a shot with the lens wide open using autofocus. Then switch to live view and take a shot after manually focusing using the rear LCD. Compare the two images. The manually-focused shot should be the sharper. If the AF shot is significantly worse then you may benefit from MFA.
The other reason to purchase FoCal is for its play value. The Pro version gives you loads of toys and I reckon it was worth the extra.
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
jaomul
Joined Apr 2011
May 07, 2013 06:26 |  #4
Thanks. I think one lens is focussing badly but my attempts at adjusting it are more miss than hit. I wil try again before I buy.
rejay14
Gallery: 38 photos
May 07, 2013 08:38 as a reply to  @ jaomul's post |  #5
I used it to adjust my 7D and 5Diii, all lenses "needed" a little bit. I'm much more than an enthusiast and I want to do all I can to get the sharpest shot imaginable, and I have been, so I'm glad I took the time to do it.
1DX Mark II, 5D Mark IV, 40D,Rebel XT :lol:, 70-200L 2.8 IS II, 100-400L IS II,24-105 II L, 100mmL 2.8 IS, 16-35L 2.8 II, 24-70 2.8L II, Sigma 50mm 1.4 Art, Sekonic 758DR, Pixma 9500 II, Pixma 9000 II, Think Tank Airport Accelerator v2.0, Canon 600EX-RT x 5, Profoto B1 x 4 with too many modifiers http:// …www.PrestigePhotoPro.c​om (external link) Portfolio (external link)
Concert Photography (external link)
jaomul
Joined Apr 2011
May 07, 2013 08:59 |  #6
rejay14 wrote in post #15906302 (external link)
So you would recommend it then? Which version did you use?
chuckmiller
Gallery: 65 photos
Joined May 2012
May 07, 2013 09:13 as a reply to  @ rejay14's post |  #7
My experience has been different from Frank's. I'm nothing but an enthusiast/shoot for fun person, and probably a very poor photographer. I think a pro is expected to produce top quality pictures and he can't do so if his lens is front or back focusing on a particular camera body. Back in the day this pro would simply/have to run through numerous copies of a lens to find one that works well on his camera body. An enthusiast probably doesn't have the resources to do this so the advent of MFA in a body was wonderful. With MFA nearly ANYONE can keep their original copy of a lens and make it work well. For the most part no more trying numerous copies of a lens is required. Maybe that means news agencies that provide equipment to their shooters won't have to buy as many spare/backup lenses. And even pros get a day off to tweak/perfect their equipment. As a hobbyist I still strive for perfect, clear, sharp, whatever, images. I hope that my FoCal can see better that I can and help me to nail down the focus as needed. Before FoCal I tried shooting dozens and dozens of test images and evaluating them myself and it's a big pain in the ass. I feel using FoCal saves me a great deal of time in the beginning and then I make the last adjustment I think it needs, if any. I think FoCal or anything like it benefits pros and hobbyists equally. And, several of my lenses have needed and greatly benefited from MFA, some are adjusted by 7-10 steps. That amount is definitely discernible.
Retired from Fire/Rescue with 30 years on the job - January 2019
rejay14
Gallery: 38 photos
May 07, 2013 10:59 |  #8
jaomul wrote in post #15906374 (external link)
Yes, I'd recommend it. I used version 1.6.0 Pro. Which body are you using? The 7D uses the fully automatic measurements, but the 5Diii requires you to press the shutter yourself. It's annoying, but it works.
Jeff
Bakewell
May 07, 2013 15:45 |  #9
hollis_f wrote in post #15905884 (external link)
I hope you chose +1. It looks like the Tokina is close to perfect regardless!
Dave
pulsar123
Gallery: 82 photos
May 07, 2013 15:50 |  #10
FoCal customer support sucks big time - they never refunded my purchase, despite the fact that it never worked for me (Windows XP SP3 laptop, which is officially supported). After a few months of waiting, I gave up on them.
Dot-tune is a free method for MA calibration, apparently as accurate or even better than Focal, and much faster. It is now implemented in alternative firmware Magic Lantern (their bleeding edge nightly release), so if your camera is supported, it is by far the most convenient way to do MA.
6D (normal), 6D (full spectrum), Tamron 24-70 f2.8 VC, 135L, 70-200 f4L, 50mm f1.8 STM, Samyang 8mm fisheye, home studio, Fast Stacker
jaomul
Joined Apr 2011
May 08, 2013 01:49 |  #11
pulsar123 wrote in post #15907885 (external link)
thanks. I googled dot-tune and came up with a link to the Fred Miranda site which explained it very well and simply. i am off work next few days so will give this a try.
jaomul
Joined Apr 2011
May 08, 2013 01:51 |  #12
rejay14 wrote in post #15906804 (external link)
Jeff
Thanks Jeff, I am using a 7d. I will try this dot-tune method and if it doesn't do what i need foCal will be my next port of call
rejay14
Gallery: 38 photos
May 08, 2013 07:34 as a reply to  @ jaomul's post |  #13
Can't go wrong with trying free things first!
dave_bass5
Gallery: 34 photos
May 08, 2013 10:44 |  #14
Another good use for Focal is it gives you a shutter count :-)
Dave.
Gallery@http://www.flickr.com/​photos/davebass5/ (external link)
Canon R7 | Canon EOS-M50 | Canon 24-70 f/2.8L MKII | 70-300L | 135L f/2.0 | EF-S 10-18 | 40 f/2.8 STM | 35mm f/2 IS | Canon S110 | Fuji F31FD | Canon 580EXII, 270EXII | Yongnuo YN-622C Triggers.
2,551 views & 0 likes for this thread, 8 members have posted to it.
foCal question
911 guests, 118 members online
