Hello,
My T4i is jumping to Automatic Exposure Bracketing on its own. I can't figure out how to permanently set it so it doesn't bracket. Everything I found on the web says it should reset it when you pull the battery, memory card, power off , etc. But that isn't the case. And I'm definitely not setting it to AEB on my own.
I called Canon today and they told me to send it in. They did no troubleshooting. I would like to avoid sending it to them if at all possible. Should I be running some sort of firmware update?
Thank you in advance for your help!
