Thread started 11 May 2013 (Saturday) 01:43
QUESTION ABOUT DOF
Langin
Joined Mar 2013
May 11, 2013 01:43 |  #1
Sirs,
If we take a picture from an APS-C with Tamron 17-50 f/2.8 and another shot taken by the same camera but with Canon EF 17-40mm f/4 by using the same focal length, would the dept of field (DOF) of the two pictures be the same ?
Please explain. Thank you so much.
Langin
Nightdiver13
Unabashed nerd!
May 11, 2013 01:44 |  #2
If you're using the same aperture from the same distance, yes.
Neil
xarqi
May 11, 2013 03:27 |  #3
Langin wrote in post #15920542 (external link)
Please explain.
For normal photography, DoF is determined by 4 factors: the focal length of the lens, the f ratio (or 'aperture'), the distance to the subject in sharpest focus, and a factor called the "circle of confusion", which is most easily understood by considering it to depend on the size of the recording format used.
Since you are changing none of these parameters (assuming the distance and aperture are held constant, as mentioned above), there is no reason for the DoF to change.
Madweasel
May 11, 2013 04:39 |  #4
We've had this before. If you view both images at the same size then the APS-C version will show a smaller DOF because it is effectively a blow-up of the wider image captured by the FF sensor. Xarqi's circles of confusion are therefore magnified more, making visible the ones that were only just small enough not to be visible in the FF image, and therefore look unsharp, in the APS-C version.
Of course, the two images would not look the same because you kept focal length equal, resulting in a different field of view for each sensor size.
EDIT: Dammit, you said "same camera". MY comments all refer to the use of different cameras to match the image circles of the two lenses. With the same camera, as xarqi says, you haven't changed anything. Apologies for any confusion, circular or otherwise.
Mark.
IanE
May 11, 2013 04:41 |  #5
Nobody mentioned changing cameras. Both pictures are taken on aps-c.
www.ievenden.com (external link)
DunnoWhen
May 11, 2013 04:42 |  #6
Madweasel wrote in post #15920698 (external link)
... But the OP didn't mention anything about changing cameras:):)
My wisdom is learned from the experience of others.
musashi
Location: Winchester, CA / San Diego, CA / North Hollywood, CA
May 11, 2013 04:44 |  #7
Madweasel, he only changed lenses, not camera. Just different lens. Althought he didnt specify if its same f-stop, focal length, and distance.
“You can easily judge the character of a man by how he treats those who can do nothing for him.”
--==Gear List & Feedback==--
Madweasel
May 11, 2013 04:46 |  #8
IanE wrote in post #15920700 (external link)
DunnoWhen wrote in post #15920701 (external link)
musashi wrote in post #15920702 (external link)
Thanks all, I caught my mistake and edited my post a second after posting, when I scrolled back up. Apologies.
Mark.
Preeb
Gallery: 151 photos
Joined Sep 2011
May 11, 2013 08:05 |  #9
Sirs,
Langin
As long as you are using the same aperture, the DoF is the same. Just because you are using a lens which fits a FF doesn't make it work any differently from the lens designed for a crop sensor. Focal length, aperture, and distance from subject are the pertinent factors.
Rick
6D Mark II - EF 17-40 f4 L -- EF 100mm f2.8 L IS Macro -- EF 70-200 f4 L IS w/1.4 II TC
gasrocks
May 11, 2013 10:55 |  #10
I was always taught (and I teach) that the 4 factors are: 1 - Aperture (the one everyone figures out.) 2 - working distance. Closer = less DOF. Reason macro is such a difficult thing for many. And astrophotography does not care about DOF. 3 - MM of the lens. Teles have less DOF, wides more. 4 - Size of sensor (negative). Larger = less DOF, smaller more. Pocket P&S cameras typically have a whole lot of DOF. The reason Ansel Adams shot at f/90. Gene
Mavgirl
Joined Mar 2013
May 11, 2013 11:18 as a reply to  @ gasrocks's post |  #11
The only reasons the size of the sensor comes into play is because you would either A. Have to move to get the same framing which changes the distance to subject and the math or B. You would crop the full frame image to get the same framing as the APS-C and the perception of the depth of field could change with that.
It's not quite the same relationship as you'd have between a 35mm film SLR and a 4x5 view camera. There are other things involved in the view camera and how Ansel Adams did some of his work. As well as the fact that the smallest aperture on a view camera is f/64. But that's a bit OT and a whole other discussion.
As far as the OP's question if the math doesn't change the depth of field doesn't change.
6D/50D/350D with too many lenses
Calumet 4x5, Pentax SV 35mm, Canon A-1, Rebel G and many more toys...
dalto
May 11, 2013 11:27 |  #12
Just to be clear, if you use the same focal length but use the Tamron at 2.8 and the Canon at 4 then the Tamron will have a narrower depth of field all else being equal.
gasrocks
May 11, 2013 14:52 |  #13
Sorry, but all other factors aside, size of sensor (negative) does matter.
Preeb
Gallery: 151 photos
Joined Sep 2011
May 11, 2013 15:19 |  #14
gasrocks wrote in post #15921939 (external link)
Not if all shots are made with the same camera.
Rick
DreDaze
Gallery: 49 photos
May 11, 2013 15:36 |  #15
but if you took a picture at 50mm, f2 and 6 ft away on a crop, and on a FF camera...would the larger sensor size really give you shallower DOF...
no...it'd actually give you more DOF...
Andre or Dre
gear list
Instagram (external link)
2,283 views & 0 likes for this thread, 15 members have posted to it.
QUESTION ABOUT DOF
1188 guests, 119 members online
