Thread started 12 May 2013 (Sunday) 15:22
blacking out the background
Ltdave
it looks like im post #19,016
Gallery: 24 photos
Joined Apr 2012
May 12, 2013 15:22 |  #1
i watched a youtube vid (adorama tv i THINK) that was a speedlite workshop...
the instructor showed some images where there was a girl sort of in a 40's style outfit in what appeared to be an alley way at 1am (or whenever its darkest). there was one 'streetlight' type of illumination and it was really really Film Noir in concept...
then they showed an image of basically the same scene where his speedlight didnt fire and (in his narrative he mentioned) you could see it was more like 1PM in the middle of the day!
ive 'wasted lots of film' here lately trying to get the background on some shots around the house to completely go dark. ive cranked the SS (with corresponding HSS) all the way 1/8000' and while i can get id underexposed compared to the subject it sure seems to show a lot of detail...
ive tried changing the ISO, the aperture, shooting on manual and E-TTL, Av and E-TTL, Tv and E-TTL, manual and manual and of course all the rest of the settings and manual and they are just not working out...
ill have to see if ive saved any of them and host/post them for you...
kind of frustrating...
5d3 and 580exII if it matters...
-im just trying. sometimes i succeed
bobbyz
May 12, 2013 15:45 |  #2
gee if someone can nuke the background at 1pm using speedlite, then why would they make 2400ws or higher packs?
Hope you know how this works, looks no based on your questions. Start with sunny 16 rule and see what your flash can do.
Fuji XT-1, 18-55mm
v35skyline
May 12, 2013 15:51 |  #3
Link to video?
X100s | X-Pro1 | X-T1 | XF 14 | XF 18 | XF 35 | XF 56 | XF 60 | XF 10-24
Gear List & Feedback
adammazza
May 12, 2013 16:22 |  #4
bobbyz wrote in post #15924932 (external link)
If he knew how it worked, he wouldn't be asking the question would he? Looks like he's asking for help, not condensation.
That said Ltdave, shutter controls ambient. 1/8000 should be enough to drop out the sun even with a wide open aperture assuming you have a reasonable ISO.
Canon 5Dm3, Fuji X100T, Fuji X-T1, Fuji X70
Canon 70-200mm L F/2.8 IS
Canon 24-105mm L F/4.0 IS
Sigma 35mm F/1.4, Sigma 85mm F/1.4
Fuji 16mm F/1.4, Fuji 35mm F/1.4, Fuji 56mm F/1.2, Fuji 16-55 F/2.8
MakisM1
Gallery: 50 photos
Joined Dec 2011
May 12, 2013 16:26 |  #5
Basically you crank the aperture to f8 or something and you keep the SS at 1/250...
Setup
IMAGE: http://i37.photobucket.com/albums/e66/MakisM/Canon/IMG_5748setup.jpg
IMAGE LINK: http://s37.photobucket​.com …on/IMG_5748setu​p.jpg.html  (external link)
Result
IMAGE: http://i37.photobucket.com/albums/e66/MakisM/Canon/IMG_5746DPPg1024.jpg
IMAGE LINK: http://s37.photobucket​.com …IMG_5746DPPg102​4.jpg.html  (external link)
This was with f5.6... 1/160.. I could go to 250 if I wanted darker... and f8, IIR I had the flash at 1/4 power...
Exif intact for this too.. note the time...
IMAGE: http://i37.photobucket.com/albums/e66/MakisM/US%202012-New%20York/US%202012-Houston/BMWv1.jpg
IMAGE LINK: http://s37.photobucket​.com …12-Houston/BMWv1.jpg.html  (external link)
Gerry
oldvultureface
Gallery: 85 photos
May 12, 2013 16:39 |  #6
Ltdave wrote in post #15924890 (external link)
Sounds like you have a spill problem. If you can flag the flash or use negative fill so its light doesn't bounce into the surroundings, you should be able to get the dark background you want.
Ltdave
Gallery: 24 photos
Joined Apr 2012
May 12, 2013 20:40 |  #7
oldvultureface wrote in post #15925078 (external link)
sounds like what im looking for. ill give another go...
thanks
Ltdave
Gallery: 24 photos
Joined Apr 2012
May 12, 2013 20:55 |  #8
okay...
i was a little forgetful on some of the details in the video. i watched it nearly a year ago...
A) it was a GUY not a girl...
B) it was BHPhoto not Adorama...
C) High Pressure Sodium (he said Sodium Vapor) lamp and not the early afternoon sun...
here is the video. go to 1:11:20. its in the very tail end of the "using gels" portion and just prior to the using shutter speed to control ambient...
https://www.youtube.co​m/watch?v=5byuHJ9uBns (external link)
maybe im missing something here or maybe ive no clue. who knows...
Ltdave
Gallery: 24 photos
Joined Apr 2012
May 12, 2013 21:03 as a reply to  @ Ltdave's post |  #9
okay...
i think the spill was the right answer...
looks like re-watching this vid will get me closer to where i wanted to go....
im pretty dumb sometimes... lol
Wilt
May 12, 2013 22:00 |  #10
Spill could be the issue, if the spill is bouncing off ceiling and/or adjacent walls.
It might also be relative distance between subject and light, and distance from background to same light.
If subject is at 2.8' from light, and the background is 8' behind (and with no spill), the background receives -3EV of light compared to the subject. If he background is only 5.6' from the light, it gets -2EV of light and would never be 'black' (unless the color of the background was already black!)
But if the light starts out 8' from the subject, the background has to be 22' from the light for it to be -3EV in relative intensity!
sporadic
Gallery: 63 photos
May 13, 2013 07:22 |  #11
Ltdave wrote in post #15925724 (external link)
okay...
From watching the video, looks like a grid. At 1:12:25, he mentions a grid on the Amber gel. Around 1:07 he talks about grids and it looks like the same one he has on the red flash.
Fuji X-T1 | X-T2 | X-T3 | 35/1.4 | 10-24 | 18-55 | 55-200 | 50-140 | Rokinon 8/2.8II Fisheye | Rokinon 12/2
Fringer EF-FX Pro
7D | 300/4 L IS
1,751 views & 0 likes for this thread, 8 members have posted to it.
1590 guests, 117 members online
