Thread started 12 May 2013 (Sunday) 23:53
Quick flash gun and brolly question
Alveric
Gallery: 38 photos
May 12, 2013 23:53 |  #1
Heya,
When you guys set up your umbrellas, what's usually your zoom value for the flash gun? Is it more efficient to zoom out (even with the wide angle diffuser) or to zoom in?
Whortleberry
Joined Dec 2011
May 13, 2013 04:00 |  #2
Two things to consider here. Firstly, with the flash zoom at a fixed position, you need to think about the distance the head is from the umbrella surface.
http://www.flickr.com …in/set-72157630310760782/ (external link)
Then, with the head in a fixed position on the umbrella shaft, you need to consider zoom setting.
It's all down to individual experimenting but the imporant thing is to only change one item at once. If you're changing the position on the shaft then keep the zoom setting fixed - conversely, if you're changing the zoom setting then keep the flash head in one place. Otherwise, you'll just add further confusion.
These sketches were prepared for another purpose altogether, but I hope they'll suffice to at least steer you in the right direction.
BTW, don't change the umbrella to subject distance - adding a third variable will make things impossible to tie down to a working solution. And leave the brave horseman out of the equation too :D
Phil ǁ Kershaw Soho Reflex: 4¼" Ross Xpres, 6½" Aldis, Super XX/ABC Pyro in 24 DDS, HP3/Meritol Metol in RFH, Johnson 'Scales' brand flash powder. Kodak Duo Six-20/Verichrome Pan. Other odd bits over the decades, simply to get the job done - not merely to polish and brag about cos I'm too mean to buy the polish!
FlickR (external link) ◄► "The Other Yongnuo User Guide v4.12" by Clive Bolton (external link) ◄► UK Railway Photographs 1906-79 (external link)
Alveric
Gallery: 38 photos
May 13, 2013 12:38 |  #3
Thanks for the reply. Cool diagrams.
Looking at this one (external link) you have there, I'm suddenly reminded of what triggered this question in the first place: my flash head is not dead centre.
IMAGE: http://www.diamantstudios.ca/Ablage/Bild/Examples/FG_straight_on.jpg
It can be tilted, but only by -7 degrees, and you can see that the beam doesn't hit right in the centre even then:
IMAGE: http://www.diamantstudios.ca/Ablage/Bild/Examples/FG_tilted_105.jpg
Side question: what if you use diffusers to simulate bare bulb with brollies? It seems to me that the light fills the umbrella more with it than without it:
IMAGE: http://www.diamantstudios.ca/Ablage/Bild/Examples/FG_tilted_stofen.jpg
But, of course, you'd lose intensity.
Whortleberry
Joined Dec 2011
May 13, 2013 16:34 |  #4
Referring back to http://www.flickr.com …in/set-72157630310760782/ (external link) and relating this to your images, it appears that you have the flash positioned at point C. Try backing the umbrella surface further away from the flash head and you will find that the spread of light can actually be controlled with the zoom reflector to more or less fill the umbrella surface. Basically, try the umbrella shaft only just inserted into the flash holder so that it's as far away as possible.
The problem with using a diffuser cap (Stofen or similar) is, as you say, the loss of intensity. You would also find that you lose control of the beam from the umbrella because the diffuser just spews light uncontrollably in all directions. You'll get completely different quality of lighting because a lot of the output would be reflected from areas outside the umbrella canopy. If you were to use this arrangement outdoors, you'd rapidly run out of power because of the wasted light
The offset can be cured by a simple bracket like this (external link). Doesn't need to be pretty and you may like to put a strap of some sort round flash head and bracket (a hair band or 'scrunchy' works fine) to make it even steadier. Flash fits on like this (external link) (please ignore the DIY honeycomb, again this image was taken for a totally different topic) and places the flash tube as close to the axis as you can get. This easily gets round the triangle formation you have at present. Just a bent piece of aluminium bolted to a cheap 'E'-type umbrella flash mount in place of the cold shoe - a couple of 4mm stainless bolts in place of the original countersunk ones did the job. The other bent bit is simply somewhere to bolt a Pixel TD-381 power pack on those occasions when my Godox PB960 is in use elsewhere.
Alexam
Joined Jun 2011
May 14, 2013 01:48 |  #5
You could also consider that some softboxes are supplied with a bracket to lower the flash to a central position. The box can also be turned in positions to allow a lower downturn, like the Micansu Ezy-Up Softbox
Serious about Photography - Alexam Images and APA - Associated Photographic Alliance
Visit my profiles on TFP Models & Malcolm Alexander - Star Now
Alveric
Gallery: 38 photos
Post edited over 8 years ago by Alveric.
May 14, 2013 13:43 |  #6
Well, it definitely wasn't pretty, LOL. I'll see if I can get a better piece of aluminium.
IMAGE: http://www.diamantstudios.ca/Ablage/Bild/Examples/HM_bracket.jpg
It seems that when using the cover, I don't have much choice in terms of placement along the shaft, especially if I want to remove the bottom part of it. But, when using it coverless... which brings up a side question: what about parabollic brollies? Can they be really efficiently used with speed lights? I bought mine to use for group shots, but it seems that the beam is even more collimated with these big things than with the normal umbrellas. Maybe it's time I really bought a monolight.
IMAGE: http://www.diamantstudios.ca/Ablage/Bild/Examples/Parabollic.jpg
I was trying to set it at 'Position A' in the pic above.
1,898 views & 0 likes for this thread, 3 members have posted to it.
1650 guests, 136 members online
