Thread started 13 May 2013 (Monday) 09:11
Legit question about 1D-X and other models
bent ­ toe
Gallery: 106 photos
Best ofs: 5
Joined Jul 2012
May 13, 2013 09:11 |  #1
Where are the WHEEL?!
It's really weird.. but all other Canon cameras have the PASM wheel.. how do 1D users do it?
Anyone care to explain?
/Not a troll ;)
"High life on low budget"
bent photos (external link)Portfoliobox (external link)
X-Pro1 XF 35 f/1.4
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
May 13, 2013 09:35 |  #2
That is a picture of an Old 1D,. Must be a Mark IIN given the screen size.
These older 1D bodies had a totally different menu system.
The mkIII did away with it, and they are much more similar the other canon bodies now.
that said, the wheel is not there because of weather sealing.
Instead, there are weather sealed buttons in the wheels place, which you press to then adjust these modes.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/05/2/LQ_648888.jpg
Image hosted by forum (648888) © CyberDyneSystems [SHARE LINK]
1D MkIIN top view.
There are no preset "scene" modes or "idiot" modes on a 1D.
A newer MkIV top view
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/05/2/LQ_648889.jpg
Image hosted by forum (648889) © CyberDyneSystems [SHARE LINK]
CDS' HOT LINKS
bent ­ toe
Gallery: 106 photos
Best ofs: 5
Joined Jul 2012
May 13, 2013 09:41 |  #3
CyberDyneSystems wrote in post #15927106 (external link)
Yea.. well the 1D-X does not have a wheel aswell.. so the question remains :)
X-Pro1 XF 35 f/1.4
nellyle
Joined Jan 2012
May 13, 2013 09:52 |  #4
Possibly because it's easier to accidentally knock it without realising?
Also, as mentioned, weather sealing?
5D3, 7D2, 1D3, 40D, 14 f2.8 Samyang, 17-40 L, 28-80 L, 70-200 2.8ii L, 200 2.8ii L, 200-400 L, 1.4 ii,
http://chris-stamp.smugmug.com/ (external link)
Clockwork ­ Frog
Joined Apr 2013
May 13, 2013 09:58 as a reply to  @ bent toe's post |  #5
On my 1Ds I have to press and hold the 'mode' button on the left of the top plate while turning the control dial. This changes from Av to Tv, etc. Also on the left are buttons you press and hold while turning the dial to change things like ISO, drive, AF mode, etc etc. Newer models may have a slightly different system.
Some cameras. Some lenses.
PacAce
Joined Feb 2003
May 13, 2013 11:05 |  #6
Clockwork Frog wrote in post #15927171 (external link)
Yeah, starting with the 1D Mark III, you no longer need to hold down the selection button(s) while turning the Main Dial to make your selection. :) But I still do, though, out of habit--I still use the 1D II along with the 1D III and the 1Dx.
...Leo
bent ­ toe
Gallery: 106 photos
Best ofs: 5
Joined Jul 2012
May 13, 2013 13:10 |  #7
Thanks for the replies guys.
Appreciate it.
X-Pro1 XF 35 f/1.4
apersson850
Obviously it's a good thing
Gallery: 35 photos
May 16, 2013 04:36 as a reply to  @ bent toe's post |  #8
Same solution as when the input wheel was introduced on the T90, back in 1987 or so.
Anders
bent ­ toe
Gallery: 106 photos
Best ofs: 5
Joined Jul 2012
May 16, 2013 04:41 |  #9
Aaaaand i'm now a 1Ds owner.. works like a charm without a wheel.
X-Pro1 XF 35 f/1.4
kouasupra
May 16, 2013 04:49 |  #10
bent toe wrote in post #15937033 (external link)
Glad you figure it out. Easy and simple.
PacAce
Joined Feb 2003
May 16, 2013 06:39 |  #11
Ah, but it DOES have a wheel and you DO need to use it to change modes or make other selections. ;)
Difference with the 1D series cameras is that you also have to press a button along with turning the wheel. :D
BTW, welcome to the 1D club. :cool:
...Leo
stang67
Joined Mar 2013
May 16, 2013 07:26 |  #12
I hate the mode dial wheel on my 50D now compared to how the 1D operates. Actually in general I MUCH prefer the ergonomics of the 1D series.
Canon 6D - Canon 1D Mk III - 70-200mm f/2.8L IS II | Σ 105mm f/2.8 | Canon 400mm f/5.6L | Σ 35mm f/1.4 | 17-40mm f/4L
bent ­ toe
Gallery: 106 photos
Best ofs: 5
Joined Jul 2012
May 16, 2013 13:48 |  #13
PacAce wrote in post #15937172 (external link)
Thanks!
weeeeeeeeeeeee!!!!
OMG! OMG!
IMAGE: http://25.media.tumblr.com/f1d615440bfbc19123709d848878d503/tumblr_mmwk4kUpIt1rtbm54o1_500.jpg
X-Pro1 XF 35 f/1.4
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
May 16, 2013 14:09 |  #14
Yep, that's what it's like. ;)
CDS' HOT LINKS
nellyle
Joined Jan 2012
May 16, 2013 14:29 |  #15
Pffft, the body cap isn't on straight!
2,324 views & 0 likes for this thread, 8 members have posted to it.
1456 guests, 128 members online
