Thread started 13 May 2013 (Monday) 15:09
Question...
envyuphotography
1 post
Joined May 2013
May 13, 2013 15:09 |  #1
I have a Canon 6d & a Canon T31 .. I also have a NeewerTT560 Speedlite 2 Yongnuo RF-630 C ... I am having trouble making the flash work with the triggers.. I had it once.. on the T3i.. But now I cant get it to work properly on either one.. If you had any suggestions? Everything has new batteries.. Ive even changed the settings in the cameras.. But still nothing..
v35skyline
May 13, 2013 15:15 |  #2
It won't fire at all? Are the tranceivers on the same channel?
X100s | X-Pro1 | X-T1 | XF 14 | XF 18 | XF 35 | XF 56 | XF 60 | XF 10-24
Gear List & Feedback
ksbal
Gallery: 374 photos
Best ofs: 9
May 13, 2013 17:28 |  #3
603's channel set is tiny and behind the batteries on the inside.. not much chance of bumping them unlike the 622's..
So then we look at do they talk? if you half press(the shutter), do both lights light up green on the speed light 603 trigger?
If that is yes, then we look at did it seat the foot far enough into the 603 hot shoe?
If yes then is it on the correct way? (yep, I've put one on backwards on a flash.. (face : palm))
If none of this helps.. please post a picture showing the camera and the flash with triggers.. and settings on the camera.
Godox/Flashpoint r2 system, plus some canon stuff.
nes_matt
May 13, 2013 21:49 |  #4
you probably already did these, but I'll state the obvious:
make sure you have fresh batteries in the 603's. This has caught me more than once when the lights worked but wouldn't fire the flash somehow.
I'm not familiar with the speedlite, but just make sure it is on manual model.
Canon 6D & Rebel T1i | Tokina 11-16 F2.8 | Sigma 18-50mm F2.8 EX DC Macro | Nifty-Fifty |85mm f1.8 | Canon 24-105 F4 | Sigma 70-200mm f/2.8 EX DG OS HSM
Flickr photo stream (external link)
Portfolio (external link)
Facebook Page (external link)
rivas8409
Joined Mar 2011
May 13, 2013 22:42 |  #5
I noticed my 603's do this for about the first minute or so after I turn them on. Like if they're searching for a connection. After that initial minute or so I can only assume they've "found each other" because they work like a charm.
Body: Canon 5DmkII│Canon M50
Glass: Tamron 35mm f/1.4│Canon 85mm f/1.8│Canon 24-105mm f/4L│Canon 135mm f/2L│Canon EF-M 22mm f/2.0
Lights: Flashpoint XPLOR 400PRO│Flashpoint Streaklight 360│Flashpoint Zoom Li-on│AB800
Results: WEBSITE (external link)FACEBOOK (external link)
783 views & 0 likes for this thread, 5 members have posted to it.
Question...
1590 guests, 117 members online
