magwai Goldmember 1,094 posts Likes: 17 Joined Mar 2010 Location: Guildford, UK More info | May 14, 2013 07:47 | #2 is there software that can handle raw video?
watt100 Cream of the Crop 14,021 posts Likes: 34 Joined Jun 2008 More info | May 14, 2013 11:42 | #3 magwai wrote in post #15930405 is there software that can handle raw video? good question
*sigh* Hardware Master (or something like that) 25,131 posts Likes: 45 Joined Feb 2011 Location: Phoenix, AZ More info | May 14, 2013 12:02 | #4 magwai wrote in post #15930405 is there software that can handle raw video? Like an editing program? Yes. This isn't the first camera to shoot Raw video, any good video editing program should be able to handle it. There are already codecs out for Canon's RAW video because of their cinema line of cameras.
Scatterbrained Cream of the Crop 8,511 posts Gallery: 267 photos Best ofs: 12 Likes: 4607 Joined Jan 2010 Location: Yomitan, Okinawa, Japan More info | May 14, 2013 12:13 | #5 magwai wrote in post #15930405 is there software that can handle raw video? Aside from video specific raw editing software, you should be able to pull a frame and edit it in Lr like any other DNG raw and then sync the edits to the whole segment VanillaImaging.com
JordanH Member 123 posts Joined Sep 2012 Location: Vernon BC, Canada. More info | May 14, 2013 14:49 | #6 Canon themselves have avoided any comment about Magic Lantern in the past. 60D | Canon18-135mm/f3.5-5.6 | Tokina11-16mm/f2.8 | Sigma30mm/f1.4 | YN622Cs | YN568EXs | 430EXII | CS6 | LR4 | Macs
KJacques Member 39 posts Joined Apr 2011 More info | A week and a half ago, I didn't think they would be able to pull this off. I was wrong. They will get this right and it is huge. This has the potential to be a major game changer. The 5D MKIII has officially walked away from every DSLR out there. Forget DSLR comparisons, the RAW footage coming out of the 5DMKIII is getting closer to RED and Alexa territory now. 12.5 stops of dynamic range!
magwai Goldmember 1,094 posts Likes: 17 Joined Mar 2010 Location: Guildford, UK More info | May 15, 2013 03:19 | #8 Scatterbrained wrote in post #15931254 Aside from video specific raw editing software, you should be able to pull a frame and edit it in Lr like any other DNG raw and then sync the edits to the whole segment . It's more tedious than editing in video specific software but if you just want to play around without buying new software it'll get you by.Frame-by-frame? I think I'll pass thanks.
Scatterbrained Cream of the Crop 8,511 posts Gallery: 267 photos Best ofs: 12 Likes: 4607 Joined Jan 2010 Location: Yomitan, Okinawa, Japan More info | May 15, 2013 03:22 | #9 magwai wrote in post #15933652 Frame-by-frame? I think I'll pass thanks. No. Pull a frame, edit it, and then sync the edits across all frames. You only actually edit one frame, then create a preset for the rest of the footage. It's how I do my home video as I can't stand Premier Elements. After working in Lr everything else just feels too constrained. VanillaImaging.com
Scatterbrained Cream of the Crop 8,511 posts Gallery: 267 photos Best ofs: 12 Likes: 4607 Joined Jan 2010 Location: Yomitan, Okinawa, Japan More info | May 15, 2013 03:25 | #10 Here's a link: VanillaImaging.com
outmywindow Senior Member 672 posts Likes: 3 Joined Jan 2013 More info | May 16, 2013 14:28 | #11 If Adobe can make their next release (or update) of Premiere as easy to work with for raw video as we can with lightroom and raw images - that is to say a clean and unobtrusive workflow - that would be perfect. As it is right now, you can work with raw video in CS6 but its still not that intuitive or easy to work with. Just a soul with a camera
bclark22 Member 49 posts Joined Apr 2011 Location: Norman, OK, USA More info | May 21, 2013 19:52 | #12 outmywindow wrote in post #15938471 If Adobe can make their next release (or update) of Premiere as easy to work with for raw video as we can with lightroom and raw images - that is to say a clean and unobtrusive workflow - that would be perfect. As it is right now, you can work with raw video in CS6 but its still not that intuitive or easy to work with. That would be very nice. I haven't dealt with RAW video much. Shot some on a RED once a couple years back but never got around to playing with it. Not really sure about the workflow but maybe as RAW becomes more available to the masses I will take a closer look into it.
May 21, 2013 21:43 | #13 Raw is not good so much for what you can do with it now, but what you can do with it in the future. IOW, as processing software improves you haven't burned in a rendition you had to accept when codecs, file sizes, etc. were less ideal. Doesn't change the fact that you're on the bleeding edge of things right now WRT those same constraints.
magwai Goldmember 1,094 posts Likes: 17 Joined Mar 2010 Location: Guildford, UK More info | May 22, 2013 05:28 | #14 Scatterbrained wrote in post #15933658 No. Pull a frame, edit it, and then sync the edits across all frames. You only actually edit one frame, then create a preset for the rest of the footage. It's how I do my home video as I can't stand Premier Elements. After working in Lr everything else just feels too constrained. ![]() Ok that doesn't sound too bad. Can LR 4 do that now?
bclark22 Member 49 posts Joined Apr 2011 Location: Norman, OK, USA More info | May 22, 2013 12:24 | #15 magwai wrote in post #15955772 Ok that doesn't sound too bad. Can LR 4 do that now? I always create presets in LR, but don't know about the potential of exporting thousands of frames with the same preset. My biggest worry would be that it would eat up a ton of time in LR to do all the adjustments and then wait for it to export thousands of frames, only to have to go back into a software like Premiere and put the audio back in, etc... RAW video would definitely add some extra time and steps to any workflow.
| Latest registered member is griggt 671 guests, 122 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
