billinvegas wrote in post #15928362
I was poking around on the 'net, read something that I thought was interesting.
Should have bookmarked it, but failed to do so. So, I thought I would run it past you folks here (I trust the info I get on this forum as opposed to some others)
In a nutshell: It was stated not to use stabilization at higher shutter speeds, due to a frequency effect (forget the name of it) introduced by the stabilization motor
Has anyone heard of this?
Claimed it could affect the sharpness / focus at the time the shutter is tripped.
I normally leave the stabilization turned on, even if I'm shooting past the reciprocal
(is that the right word?) of the focal length ( i.e. 1/200th for 200mm) as sometimes I shoot things in varying lighting conditions (someone in / out of a follow spot, heavily shaded areas outdoor, etc)
Should I be switching off stabilization once I get into lit areas where I can up the shutter speeds? Might be easier when I'm outdoors, but indoors, at a play or concert, I'm pretty certain I will forget to do so...
thanks!
Actual images from real stabilized lenses. Fast shutter speeds were used in each case.
Lens: EF-S18-200mm f/3.5-5.6 IS
Focal Length: 32.0mm
Aperture: f/4.5
Exposure Time: 0.0010 s
(1/1000)ISO equiv: 500
Exposure Bias: none
Metering Mode: Matrix
Exposure: shutter priority (semi-auto)
White Balance: Auto
Flash Fired: No (enforced)
Orientation: Normal
Color Space: sRGB
Lens: 150-500mm (Sigma optical stabilized lens)
Image Date: 2011-10-29 14:03:13 (no TZ)
Focal Length: 174.0mm
Aperture: f/5.6
Exposure Time: 0.0005 s
(1/2000)ISO equiv: 400
Exposure Bias: none
White Balance: Auto
Orientation: Normal
Color Space: sRGB
Lens: 70-300mm (Tamron vibration control lens)
Focal Length: 84.0mm
Aperture: f/4.0
(1/2000)ISO equiv: 200
Exposure Bias: none
White Balance: Auto
Orientation: Normal
Color Space: sRGB
In none of these examples and in none of countless other images taken with a stabilized lens using a fast shutter speed has the lens' stabilization introduced a "frequency effect." From actual photography and real images, this myth can be safely ignored.
