Thread started 18 Jan 2006 (Wednesday) 09:20
Replacing sky
dan_c
Joined Jul 2004
Jan 18, 2006 09:20 |  #1
Hi,
Here's a shot of the mighty Cliffs of Moher in Ireland. Just as an experiment, I replaced the sky in the original picture (which was converted in BW). Any advice or comments welcome.
Cheers,
Dan
EOS 30D
24-70 f2.8L
10-22mm f/3.5-4.5
70-200L f4
Speedlite 430EX
Scottes
Trigger Man - POTN Retired
Joined Nov 2003
Jan 18, 2006 09:31 |  #2
Dan, excellent job.
You've got a very mild halo in place along the cliff and around the castle(?) in the background. Very mild, and I only found it because I'm picky and I knew what to look for.
Excellent job picking a sky to match the scene. It fits. Good work on the reflection in the sea, but it doesn't seem to fit so great. (Hats off for remembering to do this though!) The problem I see is that the sea looks like it's reflecting a cloudless day. And the sun's reflection (in the center at the horizon) doesn't match the sun in the sky, which is over to the right a bit.
A trick that worked for me is to copy the sky to a new layer, and then mirror it and move it to the bottom half of the picture. Erase this mirrored layer leaving only the parts where the sea exists. Adjust opacity to taste.
For extra points you might want to try to add some shadow back to the left sides of the cliff and that big rock spire. The sun is up and to the right, so everything down and to the left should be in shadow. Parts of the top of the cliff - where it should be receiving more light - and darker than the sides of the cliff that can't possibly be receiving sunlight.
Again, excellent job. And again, I'm picky and know what to look for since you posted the before & after.
You can take my 100-400 L away when you pry it from my cold, dead fingers.
Scottes' Rum Pages - Rum Reviews And Info (external link)
Follower of Fidget - Joined the cult of HAMSTTR©
EOS_JD
Jan 18, 2006 21:01 |  #3
A nice job but the tweaks noted above will make this an excellent job
All My Gear
5D MkIII & 5D MKII + Grips | 24-70 f2.8L IS | 24-105 f4L IS | 70-200 f2.8L IS MkII | 50 f/1.4 | 85 f1.8 | 100 f2.8 | 1.4x MkII | Tamron 17-35 f2.8-4
Ron ­ Wilson
Jan 19, 2006 12:35 as a reply to  @ Scottes's post |  #4
The tip you suggested is really neat. I too think that he did a great job in post.
Digital Rebel XT
Canon 50MM F1.4Canon 85MM F2.8
Canon 100MM F2.8 Macro
Canon 100-400MM IS L
Lots of luck
SuzyView
Jan 19, 2006 12:38 |  #5
Superb. Artist and magician. :)
SuzyView
dan_c
Joined Jul 2004
Jan 19, 2006 14:16 as a reply to  @ SuzyView's post |  #6
Thank you all for advices. I will give it a try...
Cheers,
Dan
EOS 30D
24-70 f2.8L
10-22mm f/3.5-4.5
70-200L f4
Speedlite 430EX
IainUK
Jan 19, 2006 16:45 |  #7
I wanted to do something like this with PS Elements 3 but apparently it doesnt support the feature where you add a layer and then paint over the sky to bring Layer 1 through. Sorry can't remeber the name its a bit late :-)
If anyone has found a workaround on this in PSE 3 I'd like to hear it. Thanks
"No one ever grew by being measured...."
EOS5D / 5d MKII
580 EX II
24-70mm f2.8 L
70-200mm f2.8 L IS
1,371 views & 0 likes for this thread, 6 members have posted to it.
Replacing sky
2148 guests, 126 members online
