Thread started 14 Apr 2001 (Saturday) 19:36
Thanks to Nadim !!! And to Contrast Masking
Andrei
Joined Apr 2001
Apr 14, 2001 19:36 |  #1
Nadim,
thank you for the really effective technique of procesing high contrast pictures in PhotShop.
Who does not know about it, I highly recommend to look here
http://www.dpreview.co​m …010&page=2&mess​age=911535 (external link)
Today I made a photo of two Amherst's horse police officers. But It was very sunny day and add to that It was noon. So the original picture is here:
HTTP response: NOT FOUND | MIME changed to 'image/gif' | Redirected to error image by FOTOTIME
I tried to equalize contrast in PhotoShop using curve:
And then using Contrast Masking:
I think that Contrast Masking gives the best result with much less efforts.
Pekka
El General Moderator
Gallery: 36 photos
Best ofs: 7
Joined Mar 2001
Apr 15, 2001 09:24 |  #2
You can do about the same by converting the image to Lab mode and adjusting levels of the lightness channel. It looks more natural too (no gaussian blur halos, see e.g. the wall behind the horse). Here I adjusted lightness gamma to 1.45:
The Forum Boss, El General Moderator
AMASS 2.5 Changelog (installed here now)
Andrei
Joined Apr 2001
Apr 15, 2001 13:02 |  #3
Yes, the halo is a problem in some cases, but it can be regulated by radius of Gaussian filter. Anyway, sometimes Channel or Layer blending is the only chance to save the picture. Though I have to admit this is extreme case and not fore everyday using.
nadim
Joined Mar 2001
Apr 15, 2001 14:49 |  #4
Hi Andrei and Pekka,
There isn't a right way or a wrong way to achieve something.
The LAB "Lightness" channel adjustements allows the modification of the brightness of an image, without impacting the color components.
The Contrast masking technique's objective is to limit brightness in hi-brite area, and to increase brightness in dark areas... kind of...
Different objectives, different techniques.... Know when to use each. For a flash interior photography, where the background is underexposed, the contrast masking technique will yield better results. In photos where contrast is evenly distributed (outdoor), adjusting the Lightness channel would yield better pleasing results...
Thanks,
nadim
ps - Changing the image from RGB to LAB and vice-versa will impact the image, unlike what you may read in some articles. This is due to the integer implementation of image processing algorithms in Photoshop. Try the following: change the image from RGB to Lab to RGB. Repeat 10 times. You'll start seeing heavy pixellization... color pixellization. I bet no one would be able to see any impact with only 2 modifications, so we're safe so far.
3,482 views & 0 likes for this thread, 3 members have posted to it.
1052 guests, 104 members online
