I am looking for a mono pod for my camera. I have been looking at this one: http://www.bhphotovideo.com …Classic_Carbon_Fiber.html![]()
Can someone tell me if this is good choice? I also don't want to break the bank.
Mjasinski Member 94 posts Joined Apr 2013 More info | May 15, 2013 10:16 | #1 I am looking for a mono pod for my camera. I have been looking at this one: http://www.bhphotovideo.com …Classic_Carbon_Fiber.html Body: Canon T4i - Canon 70D
Lowner "I'm the original idiot" 12,924 posts Likes: 18 Joined Jul 2007 Location: Salisbury, UK. More info | May 15, 2013 10:21 | #2 Seems reasonable. I use a ballhead with mine which makes it simpler to use, in fact its the ballhead I rejected for tripod use so it cost me nothing more. Richard
Beaner242 Member 150 posts Joined Dec 2011 Location: Bonne Terre Missouri More info | May 15, 2013 10:36 | #3 I can understand spending that much on a tripod, but on a monopod? i got mine at WalMart for around $20 bucks and it has not failed me yet. I use it as a hiking pole as i walk also.
May 15, 2013 10:38 | #4 I just want a good one. I am looking into buying a Sigma 50-500 and I want to be sure the mono pod can handle it. I would hate for it to fail..... Body: Canon T4i - Canon 70D
May 15, 2013 10:39 | #5 Lowner wrote in post #15934495 Seems reasonable. I use a ballhead with mine which makes it simpler to use, in fact its the ballhead I rejected for tripod use so it cost me nothing more. What kind of ball head? Could you post a link? Body: Canon T4i - Canon 70D
ghost68 Member 163 posts Likes: 1 Joined Jan 2012 Location: Los Angeles More info | May 15, 2013 12:45 | #6 This Monopod
Lowner "I'm the original idiot" 12,924 posts Likes: 18 Joined Jul 2007 Location: Salisbury, UK. More info | May 15, 2013 13:07 | #7 Mjasinski wrote in post #15934561 What kind of ball head? Could you post a link? I use a very basic Manfrotto 486, nothing expensive or fancy. I removed it from the tripod as I found the camera drooping after I had carefully lined up shots. This is not something I need to fret about with a monopod. I have fitted it with an Arca-Swiss screw clamp. Richard
RPCrowe Cream of the Crop More info | A really sturdy monopod which is fairly inexpensive yet relatively light in weight is the Manfrotto 681B. It weighs just .4 pounds (6.4 oz) more than the Benro model. See my images at http://rpcrowe.smugmug.com/
CyberDyneSystems Admin (type T-2000) More info | May 15, 2013 20:05 | #9 The other very good tilt head was already linked to above. GEAR LIST
kids&birds Hatchling 1 post Joined Jun 2012 More info | May 15, 2013 22:14 | #10 I just bought a Feisol 1471 and a Kirk mpa-2 to use with my gripped 60d and 100-400. I've been very happy with it. The monopod extends longer than I need on flat ground (I'm 6'2") and is very solid. The Kirk head is terrific. The only downside is the combination is quite long when collapsed and doesn't fit in my bag. 60D gripped, Canon 50mm f1.8, Canon 18-200mm, Canon 100-400mm L, 430 EX II
May 16, 2013 09:43 | #11 What I like about the mono pod i posted is the: "flip lever lock design" can anyone tell me anything about that? Body: Canon T4i - Canon 70D
Lowner "I'm the original idiot" 12,924 posts Likes: 18 Joined Jul 2007 Location: Salisbury, UK. More info | May 16, 2013 10:33 | #12 Many here seem to prefer a twist lock design, but I'm a firm believer in the flip lock style myself. The difference is as described, levers are simple flip release and flip to lock, the twist design is rotated around the leg to lock or unlock. Richard
May 16, 2013 11:10 | #13 I get that I am just wondering the pros and cons. To me the lever design is quicker to adjust if needed. Body: Canon T4i - Canon 70D
ghost68 Member 163 posts Likes: 1 Joined Jan 2012 Location: Los Angeles More info | May 16, 2013 11:16 | #14 Just fyi the Sirui monopod has anti rotation legs so you can release them all at the same time with a quarter turn, extend the legs and then lock them down very quickly. I imagine the flip locks are a little faster BUT they weigh more and its just something to break or snag on something in the field...
CyberDyneSystems Admin (type T-2000) More info | May 16, 2013 11:23 | #15 My problem with that particular Sirui is the number of sections. I am happier with 3 or 4 sections, but then, it won't fold as small, so it depends on your own taste. GEAR LIST
| Latest registered member is johntmyers418 1177 guests, 113 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
