Thread started 16 May 2013 (Thursday) 16:17
Underexposing Good or Bad?
CameraMan
Gallery: 28 photos
May 16, 2013 16:17 |  #1
So a friend of mine has stated a few times now that he likes to underexpose his shots by one stop. Simply because when processing he doesn't lose any of the highlights when he brings up the exposure in Lightroom.
I can understand not overexposing but is underexposing any better? I try to keep te normal shots exposed as correctly as I can get them.
What do you all think?
Photographer (external link) | The Toys! | Video (external link) | Flickr (external link)
Shampoo sounds like an unfortunate name for a hair product.
You're a ghost driving a meat-coated skeleton made from stardust, riding a rock, hurtling through space. Fear Nothing!
gonzogolf
dumb remark memorialized
Gallery: 561 photos
May 16, 2013 16:22 |  #2
I wouldnt underexpose as a general rule. I guess while doing weddings its better to miss under than over because a blown white dress is a tragedy, but I wouldnt go there as a workflow.
sandpiper
May 16, 2013 17:04 as a reply to  @ gonzogolf's post |  #3
Again, I wouldn't underexpose as a general rule.
I do find sometimes, if I have a subject with white areas in bright sunlight, and I don't want to lose detail with the whites blowing out, that I may have to expose at a setting that does underexpose the rest of the scene to a degree, but that is a specific situation and I would normally try and avoid it by using a shadier spot to get the whites out of the harsh light.
I certainly wouldn't choose to always underexpose by a stop "just in case". If I think there may be an issue with whites blowing, I take a test shot and check the histogram and then set exposure accordingly. Underexposing and bringing the image up in post can cause increased noise levels amongst other things. Many people like to "expose to the right", slightly overexposing but keeping the whites under control, as that can improve the quality when you dial it down slightly, compared to the correct exposure in the first place.
Occasional "underexposure" is fine, when required to stop whites blowing out, but doing it all the time is not (IMO) good practice at all. If your friend is worried about inadvertently blowing whites, suggest they check the histogram after a test shot and then expose accordingly.
SuzyView
May 17, 2013 04:48 |  #4
I moved this thread to TALK as you don't have images to share and pros can come on in TALK to help you.
nathancarter
Gallery: 32 photos
May 17, 2013 11:53 |  #5
Expose in such a way that you don't lose detail in the IMPORTANT highlights.
Use the histogram and the "blinkies" to help you figure out what exposure values you need to accomplish this.
Remember that some highlights are unimportant and you can lose some detail there if you need to - e.g. the hottest part of the room's light sources, a specular reflection along the edge of something shiny, or some parts of a solid, flat, nontextured bright-white object. The bride's dress should never be clipping or losing detail, though.
Sometimes the meter will try to tell you that you're underexposed ... but remember that the meter wants to help you make perfectly average photos. If you want better-than-average photos, you've gotta take the meter's advice with a grain of salt.
PhotoMatte
Gallery: 29 photos
May 17, 2013 19:41 |  #6
Under exposing without using flash will definitely lead to darker images, of course. Under exposing the ambient light by one stop while using flash (on-or off-camera) to light your subject is a great way to make your images pop and you can control how much light hits the subject so a white dress will still maintain detail.
the site (external link)
the blog (external link)
Smugmug (external link)
My gear: Canon, Macintosh, Adobe
CameraMan
Gallery: 28 photos
May 17, 2013 21:30 |  #7
I'm shooting a wedding tomorrow and the groom has asked me not to use a flash. He wants all natural lighting. I suppose I can accomplish this with my 50mm 1.4 and my 70-200 2.8. I'd really like to use my 24-105. It's my go to lens especially in small spaces like the one I'll be in tomorrow. We'll see how things go.
nicksan
Man I Like to Fart
May 17, 2013 21:36 as a reply to  @ CameraMan's post |  #8
Shooting so that you don't clip highlights and also NOT using flash is a very limiting way to shoot. I almost never shoot that way.
If you had control of the lighting, that's one thing. But since you are asked to shoot without flash, I really wouldn't worry about it too much...
As for the 24-105L, it depends on the lighting. It might be too slow. That I.S. won't do jack to stop subject motion if you aren't getting fast enough shutter speed. But again, it depends on the lighting.
Personally, for anything remotely dim, I'd stick with the prime and the 70-200.
MFG
May 18, 2013 08:02 |  #9
i under expose on if
1. i need the shutter speed to be at least say 1/60 when i max out ISO4000 and f/1.4... (rare dark location)
2. actual location of photo shoot is near dark. so to correct expose for the lit subject is to underexpose.
AIPP Accredited (Australia), WPJA
Professional Wedding, Newborn and Family Photographer
https://www.scottgohph​otography.com.au (external link)
https://www.facebook.c​om/ScottGohPhotography (external link)
https://www.scottgohph​otography.com.au/blog (external link)
https://www.scottgohph​otography.com.au/babie​s-and-children/ (external link)
Gizmo1137
May 18, 2013 08:23 |  #10
Your friend is right to be concerned with the highlights and not blowing out the highlights, particularly in wedding photography, but as a general rule underexposing is not good practice. Ideally, the goal would be to make the most of the full dynamic range of the camera.
Best, Bruce
Jimconnerphoto
May 18, 2013 10:08 |  #11
I am the total opposite. I overexpose a small amount. Lightroom allows me to bring back detail in the highlights and I keep detail in the shadows. Underexposing that much then bringing the exposure back to normal will introduce noise in the shadow areas.
I would suggest you experiment on your own to see which method will work best for how you shoot and your style.
Wedding and Portraits www.jimconnerphoto.com (external link)
Commercial Work www.jamesdconner.com (external link)
memoriesoftomorrow
Joined Nov 2010
May 18, 2013 11:14 |  #12
nicksan wrote in post #15942752 (external link)
I'm the opposite I almost always shoot the majority of the day that way.
Peter
highway0691
May 19, 2013 00:19 |  #13
I find photos easier to bring back to life if they're overexposed a little. Recovering underexposed photos often results in unattractive noise.
There is nothing worse than a sharp image of a fuzzy concept. Ansell Adams
nicksan
Man I Like to Fart
May 19, 2013 00:24 |  #14
memoriesoftomorrow wrote in post #15943917 (external link)
Just in case this was misinterpreted, I meant to say shooting so that you don't clip highlights is a limiting way to shoot.
Some people worry so much about the "blinkies" that they avoid it like the plague. And again, that's very limiting.
I'm not a slave to my histogram.
memoriesoftomorrow
Joined Nov 2010
May 19, 2013 03:08 |  #15
nicksan wrote in post #15945611 (external link)
I don't bother with the histogram or blinkies. I use Liveview (exposure compensation mode) to judge and go by what I see. It works as a fairly accurate way to avoid clipping the important stuff... but I rarely touch the flash :)
Peter
4,936 views & 0 likes for this thread, 15 members have posted to it.
1669 guests, 137 members online
