So, I'm learning PS, using a bit of everything from everywhere. Mostly, right now, I'm using Kelby Training. In the video, they do some adjustments, when retouching, on blank layers and on adjustment layers, and periodically, they are using the CTRL+Shift+E to flatten and copy the layer. They are saying that it preserves your layers, in case you need to go back and change something later.
I was under the impression that if you flatten, you can no longer adjust. So, I made a few adjustments on a few layers and used the CTRL+Shift+E to flatten and copy (less than 20 steps, just to make sure that wasn't the problem), then tried to adjust something on a lower layer. I can see the change to the layer mask, but the top copy is not updated with the changes. Am I missing something? Or are they incorrect in what can be adjusted after flattening and copying? Maybe there's another step to update the layers above? They don't actually do this in the videos, they just say how it flattens and combines your adjustments into a copied layer and preserves the layers below it.
I'm using CS6. I did search, but no results come up. Perhaps I don't know how to phrase it correctly.
