In the past (more than 6 months ago) I used to perform my initial edits in LR, export as .jpeg (no resizing), then open in Photoshop for additional editing as needed (e.g. retouching).
I've recently started doing some compositing and have started to utilize the Edit In Photoshop command, rather than exporting. I found it nice that I could just save the image in Ps, and it would automatically re-import back into Lr. Tonight, while working on a project I decided that I wanted to check and see what the image dimensions were (specifically ppi) and found it to be 300ppi... I found this odd since I knew that I had cropped the original image a bit - and it's usually never a 'clean' number.
I went on to check the preference in Lightroom for External Editing and realized there was a setting for the output resolution (which is apparently how the file is sent to Ps). I wanted to leave the field blank and have Lr send the native pixels (for lack of a better term) to Ps, but found that it has to be set to a value between 72 and 600. Am I correct to assume that Lr will resample the image to whatever this value is every time I use the Edit In command?
Can someone explain why anyone would want this? Is there a better way? What am I missing?
