Thread started 18 Jan 2006 (Wednesday) 20:06
Printer Calibration Services
sito
Joined Jun 2005
Jan 18, 2006 20:06 |  #1
I have read that there are several services that create a profile for your printer/paper combination. Where can I find these services?
20D - 10-22mm - 17-85mm - 50 f/1.4 - 70-200 f/2.8L IS - 100mm Macro - 1.4x II - 420EX - Canon 550EX
cking2
Jan 18, 2006 20:36 |  #2
Here is one
http://www.drycreekpho​to.com/custom/custompr​ofiles.htm (external link)
Rick
Rick King
Gear List Here
JohnCollins
Joined Nov 2005
Jan 18, 2006 20:36 |  #3
Here are two.
http://www.cathysprofi​les.com/ (external link)
http://www.drycreekpho​to.com/ (external link)
Both have good explanations on their websites, DryCreek has more theory, if you're interested.
John
sito
Joined Jun 2005
Jan 20, 2006 05:47 |  #4
I think I will try http://www.cathysprofi​les.com/ (external link)
I will let you know how I like it
JohnCollins
Joined Nov 2005
Jan 20, 2006 06:04 |  #5
Please do! I got a monitor calibrator (you do have one, don't you?). A printer profile is my logical next step.
John
SkipD
Joined Dec 2002
Jan 20, 2006 06:15 |  #6
A few years ago I bought the original Spyder with software (Optical) for calibrating the monitor. The package also had software (Profiler Plus) for calibrating printers - ANY printer. Works quite well.
This was from Pantone/Colorvision.
Skip Douglas
JohnCollins
Joined Nov 2005
Jan 20, 2006 06:28 |  #7
Was it a visual process? Or did it involve a scanner, Skip?
John
UncleDoug
Joined Sep 2004
Jan 20, 2006 13:26 as a reply to  @ JohnCollins's post |  #8
Be sure that your print driver/RIP can handle "generic" ICC profiles.
Sometimes a profile with "seret sauce" is required.
-Uncle Doug
Canon 5D & 7D
Nikon D200 - :p
Mac and PC environment
VTour (external link)
mbze430
Jan 20, 2006 20:55 |  #9
Scanner process profiling really...really sux. I spend better part of late 2003 and 2004 suffering from good paper+ink profile because of using scanner as the profiler... stay away.
My Hub to my personal work (external link) (just click on the banners)
JohnCollins
Joined Nov 2005
Jan 20, 2006 21:15 |  #10
I've read that from a lot of other posters, too. Frankly, at $40-50 for a professional printer profile, I can't be bothered fiddling with doing one at home. Having the monitor profiling kit is money well spent. The next thing I'm doing is a professional printer scan.
John
mbze430
Jan 21, 2006 01:09 |  #11
I meant that using your scanner as the spectrometer is pain staking. Since I purchased the Eye-One spectrometer, profiling my own has been a breeze. And with the Profile Maker v5.0 I have complete utter control of all my devices.
SkipD
Joined Dec 2002
Jan 21, 2006 05:54 as a reply to  @ JohnCollins's post |  #12
John
For the printer calibration, a flatbed scanner is required. The accuracy of the scanner isn't really all that important because you get tools that let you tweak colors and intensities so that the final result matches your monitor's colors (or original subject colors if you want to do that too). The scanner just gets an image back into the computer.
Skip Douglas
UncleDoug
Joined Sep 2004
Jan 21, 2006 11:56 as a reply to  @ SkipD's post |  #13
You are totally right.
But his is an inferior way to produce a profile.
Very time consuming and not nearly as accurate as one prouced with a spectrophotometer.
This is from personal experience with MonacoEZcolor and from interactions with clients who have used the same approach, not just my ramblings.
-Uncle Doug
Canon 5D & 7D
Nikon D200 - :p
JohnCollins
Joined Nov 2005
Jan 21, 2006 13:53 |  #14
I suspect (not first hand knowledge) the difference between one of those printer profiles and one done by CathysProfiles or DryCreek would be at least as great as the difference I found going from an eyeball monitor calibrator like Adobe Gamma to a colorimeter with software.
That difference was tremendous, and that's an understatement. Eyeball "calibration" is better than flying completely blind. But not nearly as nice as flying on the latest instruments and autopilot.
JPC
sito
Joined Jun 2005
Jan 21, 2006 14:28 as a reply to  @ JohnCollins's post |  #15
John
Next week I am buying the ColorPlus monitor calibration package. I will calibrate my LCD monitor and afterwards I will get a printer profile at Cathy's. I will let you know how it works altogether.
I agree with you, John, about having a profile being done. After reading about the different possibities and pondering whether getting an inexpensive scanner profiling software, I have decided to have a professional make the profile for me. The equipment they have is far superior to anything I can afford.
Check this out: http://www.colorvision​.com …_spec_pf-rightforme.shtml (external link)
2,401 views & 0 likes for this thread, 6 members have posted to it.
2153 guests, 126 members online
