Thread started 21 May 2013 (Tuesday) 19:42
RRS vs Markins plates for 6D
DanFrank
May 21, 2013 19:42 |  #1
Look for a plate for a 6D. RRS & Markins are both the same price. Is one better than the next? Will be going on a Acratech Ballhead.
Gear "A creative man is motivated by the desire to achieve, not by the desire to beat others"
Indecent ­ Exposure
May 21, 2013 19:50 |  #2
RRS are the gold standard for plates and will yield a higher resale value than anyone making similar products. Neither will let you down.
- James -
www.feedthewant.com (external link)
500px (external link)
Gear List and Feedback
bfinta
May 21, 2013 21:13 |  #3
Also check out kirk plates, i have been using kirk plates for years and am very pleased withthe quality
JohnJ80
May 21, 2013 21:56 |  #4
If you are using a QR clamp, then pick one brand or the other and stick with it. See the caution on RRS's website.
J
Obsessive Gear List
"It isn't what you don't know that gets you in trouble; it's what you know for sure that isn't so." - Mark Twain
S_Egbert
May 22, 2013 07:42 |  #5
bfinta wrote in post #15954973 (external link)
I am a fan of Kirk plates also. They design their L-brackets to attach to the neck strap lug as well as the tripod socket whenever possible.
JohnJ80 wrote in post #15955106 (external link)
J
Caution on lever clamps only, screw clamps are no problem for mix and match.
Steve
image ­ monster
May 22, 2013 07:45 as a reply to  @ S_Egbert's post |  #6
I find it interesting that the PN-600 plate from Markins fits both the 6D and Nikon D600. I thought the 6D was much smaller than the Nikon.
6D | 5Dc | X100V | 16-35L F4 IS | 40 2.8 STM | 50 1.8 STM | 135L | 70-300L IS |
Gear
gakoenig
May 22, 2013 07:46 |  #7
If RRS is an option, RRS is the answer.
http://lu.ma (external link), greg@luma-labs.com (external link)
peter_n
May 22, 2013 09:44 |  #8
I'd get the RRS plate it will be fine with an Acratech clamp.
S_Egbert wrote in post #15955994 (external link)
The RRS B2 AS II lever clamp auto-adjusts to any A-S type plate.
~Peter
MCAsan
Joined Jun 2010
May 22, 2013 10:00 |  #9
For any body that will sit on an arca compatible clamp, get a L plate....not a flat one. The RRS plates, clamps, and ball heads are truly excellent kit.
cbowlsby
Joined May 2013
May 22, 2013 13:32 as a reply to  @ MCAsan's post |  #10
Partial to RRS whenever possible myself. Their plates are excellent!
feedback
swldstn
May 23, 2013 06:34 |  #11
Use Kirk and RRS L-brackets and Camera Plates. Kirk lens plates, and Markins Ball Heads with their screw clamps. (Q3T, Q10, and Q20)
Steve Waldstein
Love to Shoot - a Digital SLR (and now a Mirroless ILC) are my weapons of choice
20DNewbie
"don't listen to me, I'm an idiot"
May 23, 2013 08:28 |  #12
I use Kirk, Markins, and Wimberley plates and have never had any issues on my Markins head.
Christian.
Feedback: POTN - FM (external link)
jrscls
Gallery: 158 photos
May 23, 2013 16:24 |  #13
I have the RRS L-Plate on my 6D. You can't go wrong with that one.
Update: I sold the 6D and RRS L Plate, then later purchased a Sunwayfoto plate for another 6D and it fits/works great with my Markins ballhead and clamp.
Sony A1, 24-70mm f/2.8 GM II, 70-200mm F/2.8 GM OSS II, 200-600mm f/5.6-6.3 G OSS, 35mm f/1.4 GM, Viltrox 16mm f/1.8, 1.4X TC, Flashpoint flashes
sonnyc
Joined Jun 2005
May 23, 2013 17:20 |  #14
image monster wrote in post #15956003 (external link)
Many of them will fit other models.
I'm using a body plate from a 1DMKII on the 5D3 with grip now. I also used the same one on the 1D3 before.
I just need to flip it around and it fit.
Sonny
cdatar
1 post
Oct 19, 2013 06:53 |  #15
Anybody thinking of 3rd party "L" plates with any lever release clamp should probably stick with the same manufacturer as the clamp. I have 3 Arca Swiss Flip-Lock clamps and just bought 2 Kirk "L" Plates & 2 Kirk foot Plates with mixed sizes. I had to shim the bottom of the 70-200 foot plate slide smoothly when half locked & tight when fully locked without adjusting the clamp in between changes. My 1Ds MK III Kirk "L" plates is fine as is my 4.25" Henjar plate but my 7D Kirk "L" Plate is loose when in portrait but tight when in landscape & portrait side binds half way then becomes loose again. Kirks answer to my email was:"There is some tolerance with the machine. Not much, but when using the lever type it is more noticeable. You can return your order for a complete refund if you are not happy with the fit." I went with the Kirk because they are lighter than the RRS (1DS MK III Kirk "L" Plates is nearly half the weight of the RRS "L" Plate) & looked like a nicer design but their machining tolerances are allover the place. I don't own any RRS gear at the moment, but will be dumping the 7D Kirk "L" Plate on ebay (Don't want to waste more money on postage, Australia to USA) & purchase a RRS 7D "L" Plate & hope it is the same size as the Kirk & Henjar plates that I already have. Point is if you mix manufacturers with lever QR clamps it is pot luck & you could loose the advantage of the lever QR clamp. Sorry for the long one, just don't want anybody else getting caught & throwing money down the drain on poorly made plates.
6,963 views & 1 like for this thread, 16 members have posted to it.
Latest registered member is EBiffany
1388 guests, 104 members online
