Thread started 18 Jan 2006 (Wednesday) 21:28
Why do you guys use manual? AV makes more sense.
chrishunt
Joined Jan 2005
Jan 18, 2006 21:28 |  #1
I am by no means an expert on sports photography, but I know that I desire at least 1/500 and minimum DOF when shooting sports. It makes sense to me use AV, open up the aperture as wide as I can, and bump my ISO as needed to hit the 1/500 + mark. This way, I have minimum DOF and always the fastest shutter possible for each particular shot.
Why do so many of you shoot in manual or TV for sports? I wouldn't like TV because my DOV may be increased, which is bad (for me), and manual seems strange because lighting conditions change rapidly when outdoors and vary indoors as well depending on where you stand.
I always use custom WB, but am I missing something by not using manual exposure?
instagram/huntca (external link)
Croasdail
making stuff up
Gallery: 19 photos
Jan 18, 2006 21:38 |  #2
Well, there are so many things that can trick the camera's readings, glare from the floor, light colored uniforms, etc. By reading off of skin tons, then locking that down, you can be assured the people in the shot come out looking proper. That is my reasoning... not sure about anyone else....
Tom ­ Reid
Jan 18, 2006 21:41 |  #3
Good question burnt. I always shoot manual so I can drop the shutter speed to grab a slightly overexposed yet managable closeup player shot in between the action.
http://www.tomreidphot​ography.com/ (external link)
Unless a man undertakes more than he possibly can do, he will never do all that he can. ( ~Henry Drummond )
cyber_m0nkey
Jan 18, 2006 21:47 |  #4
If the lighting that your shooting in is reasonably consistent then go M if it is variable the shoot TV and fix the background in PP if necessary. Better to get the shot with too much DOF then not at all...
Images (external link)
Gear
chrishunt
Joined Jan 2005
Jan 18, 2006 21:51 as a reply to  @ Croasdail's post |  #5
That makes sense, but if shooting outdoors, don't you get some photos that are radically over or under exposed because of the light changes? Do you have to constantly chimp the histogram to check your manual settings?
Bass ­ Ackwards
Jan 18, 2006 21:53 as a reply to  @ cyber_m0nkey's post |  #6
I agree with you cyber...better to get the shot and fix it later. I use manual because I can under/over expose to my hearts desire, and PP it later. I would rather lose a little DOF than get a blurry image, just my .02...
Getting out of photography for now...
chrishunt
Joined Jan 2005
Jan 18, 2006 21:53 as a reply to  @ Tom Reid's post |  #7
Why would you lower the shutter speed and overexpose to get a closeup? Wouldn't a higher shutter speed and a properly exposed image be more managable? :confused:
chrishunt
Joined Jan 2005
Jan 18, 2006 21:58 as a reply to  @ Bass Ackwards's post |  #8
That makes sense to me if you shoot RAW. You could under expose to get the shutter speed where it needs to be, and then fix it in PP. I just feel like if the light is there and your getting the shutter speeds you need anyway (which I find is most of the time), then AV will allow you to get properly exposed images when the lighting changes slightly.
So the main reason to shoot manual would be to avoid your meter messing up the exposure? If your shooting in non-tricky conditions (basketball court) would it then be non-advantageous to use manual because the meter has a pretty easy job of figuring out exposure?
Crashoran
Joined Nov 2005
Jan 18, 2006 22:07 |  #9
If I was going to shoot sports in a mode other than Manual, I would definately choose TV priority. But I always shoot manual in basketball because I already know my limits in our gym. But when I go to a different setting (gym, field) things would change.
Bass ­ Ackwards
Jan 18, 2006 22:07 |  #10
True, but in manual, you can shoot lower ISO, hence lower noise, and fix the exposure later, giving you the shutter speed you need.
liza
Jan 18, 2006 22:08 |  #11
I used to use Av when shooting basketball and found that my shutter speeds were all over the place during one game. The reason for this is that the lighting isn't consistent throughout the gym and the lighting also cycles. I was getting blurry images as a result because my shutter was dropping down too low at times. Now I use manual to set my shutter high enough to avoid blur and set aperture a couple of stops from wide open to maximize sharpness and background blur. Does that make more sense?
Elizabeth
Blog
http://www.emc2foto.bl​ogspot.com/ (external link)
Wrench
Jan 18, 2006 22:14 |  #12
Lots of good tips here, thanks!
Tony
-60D. Sigma 10-20 EX, Sigma17-50 f/2.8 EX, Sigma 70-200 f/2.8 EX, Canon 100mm macro f/2.8, Canon 50mm f/1.8.
kawter2
Joined Aug 2004
Jan 18, 2006 22:24 |  #13
Only time I shot AV is then im constantly going back and forth in dramatically diferent light.. i.e. the players are running in and out of a HUGE wall of shade the bright spot is in direct sunlight..
Once you get comfortable with manual and understand the the way light falls, you will be much more confident to set exposure and not worriy about it
Wedding Blog (external link)
Eric J. Weddings (external link)
QUASIPHOTO
Joined Jun 2005
Jan 18, 2006 22:24 as a reply to  @ Wrench's post |  #14
One good reason for me.......like Mark and Liza have stated, in a gym the lighting can be all over the place. Since I started to shoot in M, my shots have been more consistent. i.e. when I first started to shoot indoors, I shot in Av mode wide open, what would happen was that the camera would meter off of what ever it choose. So say I was shooting in the directiion of a bright back light........say a light on the wall or a door open to the outside. The camera would meter off of that and my subject would be horribly underexpoused. So now shooting in M, I tell the camera what I want and I'll get good subject exposure and blown out backlighting, which I can live with.
Canon 20D w/Grip, 70-200 f2.8L IS USM, 24-70 f2.8L USM, 17-85 USM, 85 f1.8 USM, 1.4 TC, 580EX, manfrotto monopod, Omnibounce
www.flickr.com/photos/​quasiphoto (external link)
chrishunt
Joined Jan 2005
Jan 18, 2006 22:26 as a reply to  @ liza's post |  #15
Thanks for posting Liza.
This does make sense to me. I notice that my shutter speeds are all over the place as well. In a gym, I suppose lighting conditions are not severely different from one place to the next, so even though each picture may have a slightly different exposure, it may not make a difference. I think I remember you shooting in RAW, and that would help as well with those couple of shots that the exposure may be off. Do you have a certain process that you go throgh to set your exposure for a game? Do you meter off the floor, or maybe the players during warmups?
How about you people that shoot outdoor sports. Would you recommend manual settings when shooting outdoors? When I'm outside, the light changes by the minute and I can't see how manual would work in those conditions without chimping every couple minutes or so.
59,583 views & 1 like for this thread
Latest registered member is Cut Out Way
631 guests, 180 members online
