Thread started 22 May 2013 (Wednesday) 06:48
check your camera diopter adjustment
MCAsan
Joined Jun 2010
May 22, 2013 06:48 |  #1
Remember to adjust and recheck your camera body's diopter adjustment. That is the small wheel on side of the viewfinder. What does it do? It will allow you to dial in optical correction so you can clearly see the camera info (aperture, shutter, ISO..etc.) at the bottom of the viewfinder screen....and....more accurately do manual focusing.
I had set mine many months ago. This weekend I was doing macro work on flowers using manual focus. I could not get it spot on. Then I double checked the the manual focus against the AF. Sure enough AF even looked soft. I check the diopter and sure enough it was out just enough that when using AF, especially on large subjects, I did not see that my display was off as the images back at the computer were fine. But doing macro manual focus means you need to see the subject as clearly as possible.
So this is just a friendly reminder, especially for those of us who are old enough to have presbyopia and us reading glasse,.....check the diopter setting.
djohnfot
May 22, 2013 15:20 |  #2
good advice :D
bent ­ toe
Gallery: 106 photos
Best ofs: 5
Joined Jul 2012
May 22, 2013 16:02 |  #3
Good call
"High life on low budget"
bent photos (external link)Portfoliobox (external link)
X-Pro1 XF 35 f/1.4
90c4
May 22, 2013 16:10 |  #4
I have to adjust mine almost every time I use it. Wish they had a locking feature.
www.facebook.com/stage​shooter (external link)http://www.facebook.co​m/stageshooter (external link)
M_Six
Gallery: 68 photos
May 22, 2013 18:44 |  #5
I found the same thing and left the same advice on another forum. If you're manual focusing, a properly set diopter is vital. Plus it makes it *so* much easier to focus with the Eg-S screen.
Mark J.
Gear
watt100
May 23, 2013 04:37 |  #6
90c4 wrote in post #15957659 (external link)
your diopter wheel must be loose
90c4
May 23, 2013 06:26 |  #7
No - I just bump my camera bodies a lot when I'm wearing them. Until Canon had mode dial locks those would get switched constantly as well.
watt100 wrote in post #15959173 (external link)
Talley
Talley Whacker
Gallery: 46 photos
Joined Dec 2011
May 23, 2013 07:19 |  #8
I usually hack mine to provide 30% faster boot times :)
A7rIII | A7III | 12-24 F4 | 16-35 GM | 28-75 2.8 | 100-400 GM | 12mm 2.8 Fisheye | 35mm 2.8 | 85mm 1.8 | 35A | 85A | 200mm L F2 IS | MC-11
My Gear Archive
archer1960
Gallery: 6 photos
May 23, 2013 10:55 |  #9
Mine gets bumped all the time, but usually when I'm doing manual focusing, I'm using live view, so am not so badly affected by it.
Gripped 7D, gripped, full-spectrum modfied T1i (500D), SX50HS, A2E film body, Tamzooka (150-600), Tamron 90mm/2.8 VC (ver 2), Tamron 18-270 VC, Canon FD 100 f/4.0 macro, Canon 24-105 f/4L,Canon EF 200 f/2.8LII, Canon 85 f/1.8, Tamron Adaptall 2 90mmf/2.5 Macro, Tokina 11-16, Canon EX-430 flash, Vivitar DF-383 flash, Astro-Tech AT6RC and Celestron NexStar 102 GT telescopes, various other semi-crappy manual lenses and stuff.
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
May 23, 2013 11:01 |  #10
I guess this is systemic then, as every Canon DSLR I have owned must have had a "loose" diopter adjuster.
CDS' HOT LINKS
teekay
Joined Apr 2001
May 23, 2013 11:13 |  #11
The solution is to carefully put a small blob of adhesive ("GOO" is what I use) on the edge of the wheel to stop it turning after you have it set right. I've used this on several cameras and then just picked it off before selling.
BrickR
Joined Mar 2011
May 23, 2013 14:25 |  #12
I've never had the problem but you make a very good reminder, especially in threads where people believe they have a camera or soft/OOF lens issue :)
My junk
The grass isn't greener on the other side, it's green where you water it.
Rafromak
May 23, 2013 14:46 |  #13
I gave my 40D to my oldest son, and a couple of days he calls me to ask me why the subject looks like it's out of focus when he is looking through the viewfinder, but that the photos look sharp.
I forgot to tell him about the camera's diopter. I told him, "look at the very small wheel by the right upper corner of the viewfinder. Turn this wheel just like you do with the eyepiece diopter of your riflescope."
The diopter adjuster on the 7D is tight, but not the one on the 5DII. I just checked my cameras, and the 5DII was off. :)
7D, 5DII
icacphotography
Joined Jan 2013
May 23, 2013 14:54 |  #14
I wear my glasses for distance and my diopter on my XTi was never perfect on my 50D I adjusted it and my viewfinder is now tack sharp so my images are exactly what I see through the VF :D
Body:50D gripped Magic Lantern'd
Lenses:50mm 1.8,40mm 2.8,28-105 USM II,70-210 F4, 1962 Asahi Pentax Super Takumar 55mm 1.8
Flash: Canon 430 EX
The camera is just a tool - it is not responsible for the picture.
gjl711
May 23, 2013 14:59 |  #15
Adjusting the diopter is always a good idea, but why use the VF when shooting macro? It's so inaccurate to begin with even when adjusted properly. For macro live view and 10x zoom is the only way to go.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
2,960 views & 0 likes for this thread, 14 members have posted to it.
913 guests, 119 members online
