hello
which is better to use with my 5D Mark III body
i want to use it for family photos indoors
moltengold Goldmember 4,296 posts Likes: 10 Joined Jul 2011 More info | May 22, 2013 08:33 | #1 hello | Canon EOS | and some canon lenses
ksbal Goldmember More info | May 22, 2013 08:38 | #2 Either will work well with a 5D3. Godox/Flashpoint r2 system, plus some canon stuff.
May 22, 2013 08:54 | #3 thanks | Canon EOS | and some canon lenses
xhack Goldmember 1,283 posts Likes: 2 Joined Jul 2007 Location: Edinburgh, Lothian More info | May 22, 2013 09:02 | #4 I have both; to me the choice is more about ergonomics than anything else, including price: ~ Wallace
May 22, 2013 09:05 | #5 moltengold wrote in post #15956238 thanks i had the two but i want to sell one of them which one i would keep ? Thanks So you have both and you're asking us which one YOU should keep?
zerovision Goldmember 1,204 posts Likes: 3 Joined Aug 2008 Location: Dallas/Ft Worth area More info | May 22, 2013 09:12 | #6 Also, please consider if you plan on adding more units later on. The 580EX II will act as the master flash as well as a slave flash, but the 430EX II can only be set up as a slave. If your concerned about price you can consider the 580EX. It is still an excellent flash unit and puts out more power than the 430EX II.
zerovision Goldmember 1,204 posts Likes: 3 Joined Aug 2008 Location: Dallas/Ft Worth area More info | May 22, 2013 09:15 | #7 Well, since your trying to figure out which one to sell, my post doesn't really apply. So my suggestion is to sell them both and get a 600RT and the ST-E3-RT.
May 22, 2013 09:15 | #8 Thanks all for the info | Canon EOS | and some canon lenses
May 22, 2013 09:18 | #9 zerovision wrote in post #15956308 Well, since your trying to figure out which one to sell, my post doesn't really apply. So my suggestion is to sell them both and get a 600RT and the ST-E3-RT. thanks this is a good point | Canon EOS | and some canon lenses
Tessa Playing with fire 1,705 posts Likes: 59 Joined Sep 2008 More info | May 22, 2013 14:51 | #10 xhack wrote in post #15956272 ~ the head on the 580 turns 180º in both directions, which facilitates rearward bounce . ~ the head on the 430 rotates just 90º clockwise which is rather cramping when bouncing portrait in the traditional orientation. That's the part I hate about my 430 - its head can't turn 180º in both directions. So annoying when using bounce. Pull the lever, Kronk!
jlambe Member 55 posts Joined Jul 2003 Location: N.Ireland More info | May 22, 2013 14:58 | #11 No brainier keep the 580 much more versatile. Canon 5D MKII. Canon 24-105 f4 Canon 70-300 2.8 MKII Canon 50mm f1.4 Canon 100mm f2.8 macro
May 22, 2013 16:16 | #12 jlambe wrote in post #15957405 No brainier keep the 580 much more versatile. Thanks a lot | Canon EOS | and some canon lenses
| Latest registered member is semonsters 1468 guests, 130 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
