Thread started 23 May 2013 (Thursday) 05:37
Very dark viewfinder (7D)
Megapixel123
Joined May 2013
May 23, 2013 05:37 |  #1
So, I'm getting into macro and whenever I have my extension tubes with my 50mm lens, my viewfinder is always so dark even in broad daylight that I can barely ever get a shot worthy of keeping, let alone getting in focus at all. One of my best friends, who shoots Nikon was taking pictures with me the other day, and with the same lens / extension tube setup, his viewfinder was broad as daylight. Does anyone know why?! I'm getting very discouraged.
7D | 430ex II | 70-200 2.8L IS | 50mm 1.8 | 65mm 2.8 MP-E | Sigma 10-20mm f3.5
Eric S.
davidfarina
Gallery: 43 photos
Joined May 2013
May 23, 2013 05:43 |  #2
Does your images look the same as they do when you look through the viewfinder?
Maybe the aperture wont work with your extension tube...
Another question: is it a real extension tube or is it a reverse ring?
Sony A7RII | Sony A7S
EF 40 | EF 70-300L | FD 35 Tilt-Shift
FE 16-35 | FE 28 | FE 90
CV 15 4.5 III | CV 40 1.4 MC | Summilux 50 ASPH
Website (external link) | 500px (external link)
Megapixel123
Joined May 2013
May 23, 2013 05:48 |  #3
davidfarina wrote in post #15959228 (external link)
The images tend to look the same, but it's hard to tell when the viewfinder is so dark.
The aperture doesn't work when the extension tubes are on, but I change it using the DOF preview button. They are real extension tubes. I also have a reverse ring, and it does the same thing.
Eric S.
John ­ from ­ PA
Joined May 2003
May 23, 2013 05:50 |  #4
You can't be using the same extension tube/lens setup on both a Canon and Nikon. Show us the equipment you are talking about or give us specifics.
Megapixel123
Joined May 2013
May 23, 2013 05:53 |  #5
John from PA wrote in post #15959234 (external link)
We are both using the 50mm 1.8
http://www.ebay.com …Tubes&hash=item​5d3f0a00a6 (external link)
I use those, he uses the exact equivalent but for Nikon
Eric S.
jaomul
Joined Apr 2011
May 23, 2013 06:04 |  #6
Are you stopping down your lens before putting them on your ext tubes? If you have your aperture at f8 and your buddy has not you will be darker. Canon cameras (and I am sure nikon also) leave the aperture open for metering and stop down when the shutter is pressed. I assume you are pressing the dof button, then removing your lens and taking it off and putting it on with the tubes. This will always make the viewfider darker as you now are letting very little light in to visualise your shot. Try not stopping your lens down before the tubes to see what I mean. Is your friend doing the same actions as you?
Olympus EM5,Nikon d7200,
Olympus 12-50mm, 40-150mm,17mm f2.8,Nikon 50mm F1.8, Tamron 90mm vc, 18-105mmVR, Sigma 18-35 f1.8
Megapixel123
Joined May 2013
May 23, 2013 06:15 |  #7
jaomul wrote in post #15959252 (external link)
This makes alot more sense to me.. Another dumb realization I should've noticed before, lol. So basically I need to invest in better extension tubes, or a dedicated macro lens. Thanks!
Eric S.
jaomul
Joined Apr 2011
May 23, 2013 06:21 |  #8
Megapixel123 wrote in post #15959262 (external link)
To be honest, the non electrical extension tubes are difficult to use and for me at least, take the fun out of taking the photos. The electrical ones (sometimes labelled as autofocus capable) are much better. You will still likely use manual focus for most items but at leat you can select an aperture that gives you your desired dof and still see through your viewfinder. If you decide to move on then to a dedicated macro lens the extension tubes can also be used with the lens to give magnifications greater than 1:1. Kenko make well reviewed sets of these. Take care
3,609 views & 0 likes for this thread, 4 members have posted to it.
1497 guests, 188 members online
