this turned out ok, there are some ghost images along the shore line i will have to take out one of hte pictures if i can, i guess its just not matching up correct
well a few of the pictures
webejamn Goldmember 1,488 posts Likes: 8 Joined Jun 2005 Location: kalispell montana More info | Jan 19, 2006 05:39 | #1 this turned out ok, there are some ghost images along the shore line i will have to take out one of hte pictures if i can, i guess its just not matching up correct http://www.imdb.com/name/nm0000188/
wolverinesr1 Goldmember 1,671 posts Likes: 314 Joined May 2004 Location: S.E. Michigan More info | Jan 19, 2006 05:59 | #2 looks like a good pano from what i can tell. i also get the same results with the tops or bottoms not lining up perfectly.(even when using a tripod)usually i can usually fix mine by cloning in extra sky or cropping down to lowest one
Jeff
rickc Senior Member 678 posts Likes: 24 Joined Dec 2002 Location: Eagle Idaho More info | Jan 19, 2006 10:11 | #3 I would also remove the dark vertical line at the extreme left side of the picture. rickc..
webejamn THREAD STARTER Goldmember 1,488 posts Likes: 8 Joined Jun 2005 Location: kalispell montana More info | ya but thats now what i was talking about there are ghost images in the trees against the lake. that stuff is all easily fixed with cropping http://www.imdb.com/name/nm0000188/
wolverinesr1 Goldmember 1,671 posts Likes: 314 Joined May 2004 Location: S.E. Michigan More info | Jan 19, 2006 15:04 | #5 oh, i see what you are talking about now.i had to look close. i have never seen that issue before.but i have only done 10 or fewer panos. Jeff
Dimitri_V Cream of the Crop 9,221 posts Joined Nov 2004 Location: Scotland More info | Jan 19, 2006 16:26 | #6 Permanent banwebejamn wrote: this turned out ok, there are some ghost images along the shore line i will have to take out one of hte pictures if i can, i guess its just not matching up correct well a few of the pictures A bit more work probably,the place though looks absolutely stunning. My site
geokuf Member 53 posts Joined Mar 2005 Location: Northern California - USA More info | Jan 19, 2006 21:35 | #7 Are you taking pano pictures using panorama head on a tripot? geokuf
webejamn THREAD STARTER Goldmember 1,488 posts Likes: 8 Joined Jun 2005 Location: kalispell montana More info | ya, i am useing a tripod usually i dont remmber about this one, i used the 50mm lens, http://www.imdb.com/name/nm0000188/
| Latest registered member was a spammer, and banned as such! 2000 guests, 98 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
