Thread started 25 May 2013 (Saturday) 15:49
What to place between carpet and seamless paper?
fashionrider
Joined Dec 2011
May 25, 2013 15:49 |  #1
Hey guy, in my living room (the only part of the house that has high ceilings, and has enough space to act as a studio), I have soft carpeting. I like shooting with seamless paper, but if I put that on carpet, a model standing on it would create wrinkles and stuff all around. I want to put something on top the carpet, something hard so that the model can step on the paper over it with heels and not poke through.
I've used plexi-glass over the paper both for reflections and as a hard surface, but it gets costly. Where I'm located, it's $70 per sheet, and I need 2 to cover the area needed.
Are there any cheaper options. Better if it can be folded away and stored instead of being one giant solid sheet.
Gear List (5D3, 70-200 f2.8L IS II, Sigma 85mm f1.4, Sigma 35mm f1.4, 50 f1.8, 24-105L, Alien Bee lights, etc etc)
DavidR
May 25, 2013 21:27 |  #2
A sheet of plywood.
You could also use laminate wood flooring. It is cheap, snaps and unsnaps together easily and would be easy to store when not in use. It could also be used as the flooring in some of your photos.
Sony a9II
Echo63
May 26, 2013 01:57 |  #3
A sheet of plywood is normal underlay for seamless on carpet - its cheap, light and solid.
The laminate flooring is a great suggestion too
My Best Imageswww.echo63.deviantart.​com (external link)
Gear listhttps://photography-on-the.net …p?p=2463426&pos​tcount=385
mike_311
Checking squirrels nuts
Gallery: 18 photos
Joined Mar 2011
May 27, 2013 10:48 |  #4
laminate floor is a bad suggestion. when you lay out on a carpet it will fold on the seams. plywood is a better solution.
Canon 5d mkii | Canon 17-40/4L | Tamron 24-70/2.8 | Canon 85/1.8 | Canon 135/2L
www.michaelalestraphot​ography.com (external link)
Flickr (external link) | 500px (external link) | About me
Thomas ­ Campbell
Joined Jun 2010
May 27, 2013 11:08 |  #5
Sheet of plexi over it so the people have some reflection and don't look like they are floating.
Houston Wedding Photographer (external link)
Houston Sports Photographer (external link)
Current Gear List
fashionrider
Joined Dec 2011
May 27, 2013 13:39 |  #6
Thomas Campbell wrote in post #15972087 (external link)
yes, I've mentioned I use a sheet of plexi for the reflections. I just need something for underneath. I'll take a look at the suggestions these guys have made so far.
1,549 views & 0 likes for this thread, 5 members have posted to it.
864 guests, 163 members online
