Thread started 26 May 2013 (Sunday) 13:55
off camera cord
jlstan
Gallery: 28 photos
Joined Feb 2012
May 26, 2013 13:55 |  #1
I bought a 32 ft off camera flash cord for my speed-lite however it is not very reliable.
sometimes the camera sees it then the next shot the camera (7D) will not. Anyone else experience the same type of problems with off brand cords. I like using high speed shutter off camera and want something I can rely on, recommendations? The cord I bought is made by Interfit strobies and am using it with my 430exii strobe and 7D
klr.b
May 26, 2013 14:47 |  #2
For a little bit more than that Interfit cable, you could buy a set of Yongnuo YN-622C triggers. They're radio triggers so you don't have to worry about distance or someone tripping over your cable.
gordon
Gear and Feedback
JeremyKPhoto
Joined Apr 2012
May 26, 2013 14:50 |  #3
klr.b wrote in post #15969450 (external link)
True, but then he would lose the ability to use HSS if he wanted. He would also lose ETTL and controls on the camera for the speedlite. Oops, thought he said 602 triggers. 622 triggers work great with HSS and ETTL :)
Perhaps you are trying to take pictures too fast and the flash has not had time to power up again? Be sure the flash is on the mount completely and make sure the cable is 100% connected to the camera. A long time ago when I used cables I never had this problem.... and I was using a 50ft ethernet cable.
5D Mark III / 70-200 2.8L IS II / 24-105L / 50 1.8 stm / Tamron 70-300 VC / Sigma 85mm 1.4 Art
klr.b
May 26, 2013 15:19 |  #4
Ratjack wrote in post #15969459 (external link)
Why would he lose any of those? :confused:
gordon
Gear and Feedback
JeremyKPhoto
Joined Apr 2012
May 26, 2013 15:22 |  #5
klr.b wrote in post #15969549 (external link)
lol. for some reason I thought you said to get yn-602 triggers. I read it wrong :P
jlstan
Gallery: 28 photos
Joined Feb 2012
May 26, 2013 15:30 as a reply to  @ klr.b's post |  #6
Not taking pictures to fast. It seams when I take the cord off and on again a few times it will then work. Not sure if when the camera goes to sleep mode it drops everything and then does not see the flash unless I start all over. The camera gives me a message incompatible flash, however the flash does works great in the shoe alone
silvex
Gallery: 21 photos
May 26, 2013 15:32 |  #7
The flash might also got to sleep.
-Ed
CPS Platinum Member.
Canon Gear
SilvexPhoto.comexternal link
jlstan
Gallery: 28 photos
Joined Feb 2012
May 26, 2013 15:38 |  #8
silvex wrote in post #15969596 (external link)
I've been watching that ...red ready light has been on when it happens
JeremyKPhoto
Joined Apr 2012
May 26, 2013 16:58 |  #9
hmmm maybe you have a bad cable. Do you have another cable to test with?
Whortleberry
Joined Dec 2011
May 26, 2013 18:24 |  #10
jlstan wrote in post #15969592 (external link)
Not taking pictures to fast.(1) It seams when I take the cord off and on again a few times it will then work. Not sure if when the camera goes to sleep mode it drops everything and then does not see the flash unless I start all over. (2) The camera gives me a message incompatible flash, however the flash does works great in the shoe alone
(1) That sounds distinctly like poor contacts to me.
(2) Not surprisingly, that also sounds like poor contacts.
It may be just dirty contacts on one end or the other on the cord end boxes themselves. However I suspect that you have either a loose wire within the block on the cord end or an actual broken wire somewhere within the cord. The wires inside these things are really flimsy, usually something like 7 strands of copper thinner than baby hair. It's extremely easy to break one without knowing it. Given the low cost, I'd suggest getting another and seeing if you can duplicate the fault with the new cord. Better still, as suggested by klr.b in post #2, get a pair of YN-622s and get rid of the trip-hazard altogether.
I've come across rather too many faults with Interfit equipment in the last couple of years to consider it other than mediocre, at best. Once upon a time it was good, now I'm unconvinced except for very light use - something which a 32ft long cord will never get.
Phil ǁ Kershaw Soho Reflex: 4¼" Ross Xpres, 6½" Aldis, Super XX/ABC Pyro in 24 DDS, HP3/Meritol Metol in RFH, Johnson 'Scales' brand flash powder. Kodak Duo Six-20/Verichrome Pan. Other odd bits over the decades, simply to get the job done - not merely to polish and brag about cos I'm too mean to buy the polish!
FlickR (external link) ◄► "The Other Yongnuo User Guide v4.12" by Clive Bolton (external link) ◄► UK Railway Photographs 1906-79 (external link)
phantelope
May 26, 2013 18:30 |  #11
if you can, exchange it, otherwise go wireless. You'll never look back.
40D, 5D3, a bunch of lenses and other things :cool:
jlstan
Gallery: 28 photos
Joined Feb 2012
May 26, 2013 21:17 as a reply to  @ phantelope's post |  #12
I am looking at wireless, yet I also like to control flash settings at the camera along with high speed sync
jlstan
Gallery: 28 photos
Joined Feb 2012
May 26, 2013 21:22 as a reply to  @ jlstan's post |  #13
Vello FreeWave Fusion Wireless Flash Trigger & Remote Control for Canon SLR
Anyone have any knowledge of the above triggers?
Whortleberry
Joined Dec 2011
May 27, 2013 10:03 |  #14
jlstan wrote in post #15970565 (external link)
Not direct knowledge, but reading the spec on B+H I notice that you're restricted to 1/320th shutter speed maximum - therefore no possibility of HSS ever. Personally, I think you'd be better off with a Yongnuo YN-622C (external link) set-up - less money and more versatility. There's a BIG thread on this unit on this Forum - all 163 pages of it (so far)! OK, you may have to wait a couple of weeks for delivery from China but patience is a virtue - go do something else or learn something new while you wait :lol:
jlstan
Gallery: 28 photos
Joined Feb 2012
May 27, 2013 16:36 |  #15
Whortleberry wrote in post #15971872 (external link)
YN-622c is a no brainer, Thanks...Here comes a new toy:D
2,636 views & 0 likes for this thread, 7 members have posted to it.
off camera cord
2246 guests, 126 members online
