If the variable of File Size is constant, the Superfine for resolution should generate the least compression and the best photo quality. So why does the EXIF of
superfine iindicate "compressed bits per pixel @ 5 "
the fine gives "compressed bits per pixel @ 3 "
and normal gives "compressed bits per pixel @ 2 "
The same photo shot in superfine and normal shows that the superfine is indeed the photo with more digital information..it's much clearer.
So are there different types of compression?? I am so confused!! Can someone explain this clearly
thanks!!
