Thread started 30 May 2013 (Thursday) 16:43
Backing Focusing 85L
turbolover
May 30, 2013 16:43 |  #1
Hello Guys,
Got my 85 L a few days back, found the images were soft at 1.2..., got a focus test chart printed and discovered that the lens was back focusing.
On my 7D, in MA sub menu i had to apply -13 correction to bring the focus on dot and now the result are acceptable.
Did a quick research and found that 1 out of 10 lens may need MA, some says all there lenses need a small MA. Now how much is an acceptable tolerance because -13 seems way too far from that middle point "0". Do i need to replace this lens or should continue using it because after spending so Ks of $$ the lens should work fine out of the box.
Pics of Before and After MA
regards
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/05/5/LQ_650962.jpg
Image hosted by forum (650962) © turbolover [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/05/5/LQ_650963.jpg
Image hosted by forum (650963) © turbolover [SHARE LINK]
Canon 5D Mk III, Canon 8-15mm f/4L, Canon 11-24mm f/4L, Canon 16-35mm f/2.8L II, Canon 24mm f/4 TS-EL, Canon 35mm f/1.4L, Canon 24-70mm f/2.8L II, Canon 85mm f/1.2L II, Canon 100mm f/2.8L IS, Canon 70-200mm f/2.8L IS II, Canon 200mm f/2L, Canon 300mm f/2.8LII, 3xCanon 600EX-RT, Lowepro Vertex 300 AW
Copidosoma
May 30, 2013 16:47 |  #2
I'd say you've got it dialed in perfectly. I wouldn't be too worried about sending it back or anything. After all, the whole point of having a +- 20 range is so you can use it.
If it was 18 or 19 I might be a bit worried. As you have it, it is fine.
Gear: 7DII | 6D | Fuji X100s |Sigma 24A, 50A, 150-600C |24-105L |Samyang 14 2.8|Tamron 90mm f2.8 |and some other stuff
http://www.shutterstoc​k.com/g/copidosoma (external link)
https://500px.com/chri​s_kolaczan (external link)
turbolover
May 30, 2013 16:59 |  #3
Copidosoma wrote in post #15983759 (external link)
a sign of relief! thanks :)
Silverstonev8
Joined Jun 2011
May 30, 2013 17:48 |  #4
I agree. I have dialed in every lens I have. I don't think any 1.2 would ever not need any adjustment to make it perfect...
My 85 needs -8 and if I remember correctly my 50 needs -5
Chris -- Gear List
Bonbridge
Gallery: 20 photos
Joined Jan 2012
May 31, 2013 06:26 |  #5
Not true. My 85LII is perfect at MA 0, and yes I have tested it. Zero is the best result with my copy! :)
5DII + 6D | 16-35/4.0L IS | Σ35/1.4A | 40/2.8 | Σ85/1.4A | 70-200/2.8L IS II
iMac Retina 5k | i7 | 24Gb RAM | 512GB Flash | 4GB M295X
Website (external link) | flickr (external link) | Instagram (external link)
Silverstonev8
Joined Jun 2011
May 31, 2013 06:42 |  #6
I guess saying that all will need adjustment is a bit to the extreme. I'm sure there are some perfect couples out there.
Chris -- Gear List
Christina.DazzleByDesign
Joined Mar 2012
May 31, 2013 09:02 |  #7
My 85L is perfect on my 5D3, but front focuses fairly badly on my 7D. I'm going to print a focus chart as well. I'm not sure if its exactly a lens issue, but more so the combination of it with the body.
5D3 | 7D | 85L II | 70-300L | 24-105L | Nifty Fifty | 600EX-RT_______________
| Facebook (external link) | Website (external link) | Gear List |Flickr (external link) |
turbolover
May 31, 2013 09:27 |  #8
Christina.DazzleByDesi​gn wrote in post #15985586 (external link)
May be its an issue with my camera AF, and I might havent noticed on other L lenses bc of their deeper DOF. Now I will test my other lenses too. Do post you feed back
turbolover
May 31, 2013 09:31 |  #9
Silverstonev8 wrote in post #15985315 (external link)
Rightly said
Bonbridge wrote in post #15985285 (external link)
So there are perfect copies as well.
sportmode
Joined Nov 2010
May 31, 2013 09:31 as a reply to  @ turbolover's post |  #10
My 85L needed a visit to Canon along with my 5D3. They had to fix both, and now it's a 0 MFA and pretty much dead-on. My 5D2 is a different story...
5D Mark III, 6D, EOS-M 22mm f/2 | 24-70mm f/2.8L II | 50mm f1.4 | 100L | 70-200mm f/2.8L IS II | Rokinon 8mm Fisheye
turbolover
May 31, 2013 09:38 |  #11
sportmode wrote in post #15985677 (external link)
how much were they off? What about the any other lenses you have and the 5D3
snake0ape
May 31, 2013 09:38 |  #12
The camera might be at variance from perfect focus. The lens might be at variance from perfect focus. The combined resultant of both variances is what we MA. It's not just the lens.
5Diii | 50D | 8-15L 4| 16-35L 2.8 II| 24-70L 2.8 II | 70-200L 2.8 IS II |Tamy 150-600 | Σ35Art 1.4 | 40 2.8 | Σ50Art 1.4 | 85L 1.2 II | 100 2.8 Macro | Helios 44-3 58mm f2.0 |Helios 40-1 85mm f1.5 | 1.4x & 2x teleconverters
Kevinnho
Joined Jul 2012
May 31, 2013 09:52 |  #13
turbolover wrote in post #15983746 (external link)
Hello Guys,
regards
I really like the result of your focus test. What chart did you use and can you walk me through on how to do it?
Gear: 5dIII, 35L, 85L, 70-200L II, 430EXII
turbolover
May 31, 2013 10:11 |  #14
snake0ape wrote in post #15985702 (external link)
yeah true, but do this merit exchanging the lens or is this normal and my other copy may have similar issue
Kevinnho wrote in post #15985731 (external link)
there are many, google for focus test chart. After an extensive google search that kept leading me nowhere... this is the only thing I could find...Great explaination also... the chart itself is on page 18>
http://www.dphotojourn​al.com/focus-test-chart.pdf (external link)
turbolover
May 31, 2013 10:52 |  #15
Found this interesting article, It says at one place, "...And the funny part of all this is the more expensive wide aperture lenses are the ones most likely to show the problem, because their depth of field is so narrow and the in-focus portion of the picture is so sharp compared to the out of focus portion. That $200 f/5.6 zoom is not going to show a minor front focus problem because the depth of field is about half a mile. The $2,000 f/1.4 prime has a depth of field of a few inches and any problems are immediately evident (and the owner 10 times more invested in wanting a perfect lens)."
http://www.canonrumors​.com …-is-soft-and-other-myths/ (external link)
3,470 views & 0 likes for this thread, 10 members have posted to it.
1141 guests, 170 members online
