Thread started 31 May 2013 (Friday) 16:04
5D III Underexposing - Is there a fix?
pixel_junkie
May 31, 2013 16:04 |  #1
So my 5D III consistently underexposes and it is by quite a bit (over one stop). Basically I keep EC at +1 stop to get properly exposed photos. The thing that bugs me about this the most is that unless I look at the histogram constantly, I won't know that the camera underexposes as the images look good on the LCD. That means that for every image I take, I have to keep the preview window on the histogram and I don't like that as it is the only reliable way to gage exposure. On my old 5D II I also used the histogram too but a lot less as the camera exposed properly for the most part and I din't have to depend on the histogram for proper exposer for every single shot.
What are my options? If I send it to CANON, will they be able to calibrate it or do I have to suck it up and get used to the +1 EC?
Website (external link) | Blog (external link)
gonzogolf
dumb remark memorialized
Gallery: 561 photos
May 31, 2013 16:06 |  #2
Have you shot an 18% gray card to check that the meter is actually off?
Numenorean
May 31, 2013 16:08 |  #3
What metering mode are you using? Sample shots?
I prefer to leave histogram up because that's the important thing to look at when reviewing anyway.
Chet
Gallery: 132 photos
May 31, 2013 16:08 |  #4
Odd. How are you metering? Spot, center point?
pixel_junkie
May 31, 2013 16:12 |  #5
gonzogolf wrote in post #15986876 (external link)
No, but if I'm constantly dialed +1 EC or more for the majority of my shots ... Wasn't like that on the 5D II...
Numenorean wrote in post #15986878 (external link)
I could do that but then I also have to look at the actual image to see things like composition and focus so now I'm flipping back and forth way too many times ...
pixel_junkie
May 31, 2013 16:12 as a reply to  @ pixel_junkie's post |  #6
I'm using the default spot metering mode ...
gonzogolf
Gallery: 561 photos
May 31, 2013 16:14 |  #7
well if you dont run a test using a measurable tool you cant be sure whether its the camera or some change in the settings or technique.
Numenorean
May 31, 2013 16:23 |  #8
pixel_junkie wrote in post #15986886 (external link)
You look at composition and focus through the viewfinder. Not the LCD after you've already taken the shot.
Numenorean
May 31, 2013 16:24 |  #9
pixel_junkie wrote in post #15986888 (external link)
Spot metering is only useful for certain situations and is not the idea metering mode in most cases. Try using center weighted average or evaluative mode.
Mavgirl
Joined Mar 2013
May 31, 2013 16:25 as a reply to  @ gonzogolf's post |  #10
I'd shoot a gray card and check the histogram on that image to see what's happening. And remember with a gray card the histogram won't be all spread out like with a "normal" image but will just be a peak in the middle.
6D/50D/350D with too many lenses
Calumet 4x5, Pentax SV 35mm, Canon A-1, Rebel G and many more toys...
pixel_junkie
May 31, 2013 16:48 as a reply to  @ Mavgirl's post |  #11
Under what lighting conditions would you set up a gray card shot to get the most accurate results? I use my gray card for color correction mainly ...
frugivore
Gallery: 11 photos
May 31, 2013 16:58 |  #12
The 5D2 averages the scene to be three stops below the sensor maximum. The 5D3 averages the scene to be 3.5 stops below maximum. If the scene had 7 stops of dynamic range, the 5D3 would capture it perfectly, whereas 5D2 would clip the highlights.
pixel_junkie
May 31, 2013 17:20 |  #13
frugivore wrote in post #15987011 (external link)
Is there a way to adjust that in anyway? I hate it...
RDKirk
Adorama says I'm "packed."
Joined May 2004
May 31, 2013 17:33 |  #14
Numenorean wrote in post #15986920 (external link)
I don't have a 5D3, but isn't the spot meter tighter than that of the 5D2? If so, that's going to up the rate of errors for someone who isn't using it properly.
Numenorean
May 31, 2013 17:37 |  #15
RDKirk wrote in post #15987110 (external link)
I don't have one either so I'm not sure on the coverage differences if any between the two.
12,212 views & 0 likes for this thread, 31 members have posted to it and it is followed by 4 members.
1122 guests, 112 members online
