Thread started 03 Jun 2013 (Monday) 16:46
Slave+Master on 430 EXII
ChrisAdval
Joined Mar 2013
Jun 03, 2013 16:46 |  #1
I'm having a very difficult time changing from master to slave on the 430EXII.... can anyone tell me? and yes I read the manual, it told me to go into that menu by holding zoom, did that, not able to change to slave from master...
All past and recent works on my Flickr (external link). If you're interested in checking out prints for sell of my work go here (external link). *Website (external link)*
HLxDrummer
Joined Aug 2011
Jun 03, 2013 17:01 |  #2
The 430EX can't work as a master can it?
40D with Tamron 17-50MM f/2.8 & Canon 85MM f/1.8 & Canon 55-250MM f/4-5.6
YN-565 with (2) RF-603s
1993 3000GT VR4 & 1993 Trek 2500Pro & 1980's Schwinn World Sport
ChrisAdval
Joined Mar 2013
Jun 03, 2013 17:12 |  #3
HLxDrummer wrote in post #15996139 (external link)
its on master for me... cant figure out to turn it off and move it into slave... :o
HLxDrummer
Joined Aug 2011
Jun 03, 2013 17:21 |  #4
You mean from regular mode to slave? You should just HIT zoom, not hold it. It will then prompt you for the channel/group and go into slave mode I think.
apersson850
Obviously it's a good thing
Gallery: 35 photos
Jun 03, 2013 17:30 as a reply to  @ HLxDrummer's post |  #5
Don't have any, but with the 580 EX II, you indeed hold the Zoom button to change mode from standard to master to slave and back to standard. It seems likely it's the same with the 430 EX II, except it doesn't have the master mode.
Anders
ChrisAdval
Joined Mar 2013
Jun 03, 2013 17:41 |  #6
I have tried the Zoom menu, when I toggle, the "flash" icon does not blank, only channels, groups, and zoom... it skips the flash icon as it suppose to blank when I toggle I assume?
ChrisAdval
Joined Mar 2013
Jun 03, 2013 20:42 |  #7
so... is something wrong with my 430EXII? should I contact Canon?
Tiberius
Jun 04, 2013 00:36 |  #8
Check the link for wireless flash in my signature. It has detailed instructions on how to set up your 430 as a slave and everything else you need to know.
My photography website!PHOCAL PHOTOGRAPHY (external link)
CptTripps
Joined Mar 2011
Jun 04, 2013 02:16 |  #9
Can't be a master, hold zoom to switch to slave mode which then displays channels and groups.
60D - Sigma 30mm 1.4 - 50mm 1.8 ImkII - 18-135 IS - 70-200 2.8 mkII - 2x430ex II - 3xFlextt5+AC3 - Einstein 640 w/mc2 - Vagabond Mini
apersson850
Gallery: 35 photos
Jun 04, 2013 04:32 as a reply to  @ CptTripps's post |  #10
Quick guide, with pictures (external link)
Anders
ChrisAdval
Joined Mar 2013
Jun 05, 2013 03:31 |  #11
did that, the Flash icon next to channel, is suppose to have no lines coming out of the flash icon to be on "slave" mode... right? I think thats what my manual said... but I am only able to change the channel or/and group... thats it...
Unless I am missing something? I tried to simply have it be triggered by my other flashes flashing (YN560 w/ YN622 triggers) and no flash occurred from 430EX II? Should I simply play with the channels on the 430EXII until it flashes?
apersson850
Gallery: 35 photos
Jun 05, 2013 03:41 as a reply to  @ ChrisAdval's post |  #12
Of course it should have lines coming out of the icon. They represent the light coming from the flash. No point in having a slave flash if it doesn't illuminate, is there? Besides, when you look at the picture in the quick guide you see the lines are still there, so I don't know where you got the idea that they should disappear from?
Then there's a flash symbol in front of the flash icon too. It's supposed to have an arrow pointing into the flash icon when in slave mode, to indicate reception of commands. A 580 EX II can have that arrow point either in or out, since it can be either master or slave, but your 430 EX II can only be a slave.
To fire the 430 EX II as a slave you need a controller compatible with Canon's optical slave flash protocol. Are your YN devices that, really? Try your 430 EX II with a Canon controller to verify function, before using something else.
I'm at least pretty sure we can assure you that there's nothing wrong with your hardware, so no service necessary. You just need to understand how it works.
Anders
Dannybegood
Joined Nov 2011
Jun 05, 2013 03:46 |  #13
I have a feeling that you can only trigger the 430 as a slave to the 580/550/600 and maybe the newer more expensive Yogonuo flashes. The 560 might not do this and you will need another 622
Danny,
60D,24-105 f4L,70-200 f4L,100 2.8f MACRO, Nifty Fifty, Σ120-400/20-40EX, 430 ex ii
Flikr (external link)
oldvultureface
Gallery: 85 photos
Jun 05, 2013 05:04 |  #14
ChrisAdval wrote in post #16001240 (external link)
Dannybegood wrote in post #16001257 (external link)
Exactly. The 430, by itself, will not respond to another flash unless that flash has master capability. When in slave mode, the 430 is listening for a coded sequence of light pulses from a master flash to determine what mode and what power setting to use. A single burst from another flash will not trigger it.
ChrisAdval
Joined Mar 2013
Jun 05, 2013 12:44 |  #15
oldvultureface wrote in post #16001344 (external link)
yea, my YN560 is in master and on a 622, but the 430 is alone without a 622, not triggering... do I need to play around with the channels/groups on the 430 until it flashes?
3,965 views & 0 likes for this thread, 11 members have posted to it.
1614 guests, 138 members online
