Thread started 04 Jun 2013 (Tuesday) 17:09
Specific Edge Mask Sharpening Question
RandMan
Joined Mar 2012
Jun 04, 2013 17:09 |  #1
So I have seen a lot of tutorials on edge mask sharpening, all very similar, where the composite RGB gets copied into a new channel, levels, blur, save/load channel etc. But there is just one step that I am, I guess one would say, inquisitive about. After the "find edges" command is run, why does every tutorial wait until later on to invert the mask? The reason I ask is because when you go right into "levels," you are refining your mask except contrary to your normal thought process, i.e., now you're saying to yourself, "the effect will be happening where I see black, and hidden/masked where I see white." So then, after you refine your channel, blur it, and sometimes go back into "levels" again, it is only THEN that the mask gets inverted so then you are seeing its true "intention." So my question is why not invert immediately after loading "find edges," so that you are not left to view and think backwards while you are working on it? I'm assuming there has to be a legitimate reason why, like it negatively affects the process somehow???
Curious minds want to know! Or maybe just mine.....
-Randy
Canon eos7D | Canon 50mm 1.4 | Canon 17-55mm 2.8 | Sigma 70-200mm 2.8 | Yongnuo 565ex | Yongnuo yn-468 II | Canon ef28-135mm 3.5/5.6 | Canon ef-s 55-250mm 4.0/5.6
René ­ Damkot
Jun 05, 2013 07:43 |  #2
Makes no difference, so use whatever way you like best. ;)
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
RandMan
Joined Mar 2012
Jun 05, 2013 10:11 |  #3
Just the answer I was hoping for--thank you Rene as always.
718 views & 0 likes for this thread, 2 members have posted to it.
1061 guests, 102 members online
